Ariston AVXL 129 4H lit up and not starting
When I shut the door and turn machine on, 4H lights up and on/off switch light not on, won't start and door not locking
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line.
Posted on May 02, 2013
3 Suggested Answers
hbsurfdawg
  • 95 Answers
SOURCE: ariston avxl 129 washing machine has stopped working.
This washer does not have a good track record. There are many many complaints out their on this brand in general. It is also not a cheap purchase.
1st. Suspect is the mother board followed by the motor.
Posted on Nov 20, 2011
soj_er_05
SOURCE: i have kenmore elite he5t washer and door lock light won't turn on to be abele to start the washer machine
answer of puk code
Posted on Jan 26, 2012
I am looking for user manual for washer maskin ariston AVXL 125
This should do it.
http://www.manualslib.com/products/Ariston-Avxl-105-3182207.html Ariston AVXL 105 Manuals
Sep 02, 2015 | Ariston Technologies Washing Machines
Hi there I need the manual for AUXL105
Do you mean the Ariston AVXL 105? Manual Lib has the manual here: http://www.manualslib.com/products/Ariston-Avxl-105-3182207.html . The English part of the manual starts on page 13. The section on the programs is on page 18.
I hope this helps.
(The link: http://www.manualslib.com/manual/644893/Ariston-Aml-119.html#product-AVXL%20105 has the link to download the manual.)
Mar 02, 2015 | Washing Machines
Ariston avxl 140
Check that you don't overload the machine. This can happen if the load is too heavy.
Jan 31, 2014 | Washing Machines
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Aug 27, 2012 | Kenmore 44102 Front Load Washer
Ariston avxl 129 washing machine has stopped working.
Nov 20, 2011 | Washing Machines
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Nov 17, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
