Astrum 2.4g multimedia keyboard
One touch (quick link) hot keys,found on top of all the f1-f12 keys are not functioning.there are 7 keys
    Master:
  • 663 Answers
It could be an outdated driver.
Try scanning your computer with RadarSync so that you will know if it's really outdated driver related issue. You can either use RadarSync to update for quicker and easier process or you can get the updates in the manufacturer's website.
I hope this helps!
David
Posted on May 02, 2013
  • 58 Answers
SOURCE: Multimedia keyboard on function keys. Functions
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Posted on Nov 03, 2009
  • 19 Answers
SOURCE: Need to restore F1 word function in word 2003
  1. On the Tools menu, click Customize.
  2. Click Keyboard.
  3. Click Reset All.
Note: Reset All removes your customized shortcut key assignments and restores the original Microsoft Word shortcut key assignments in the selected template or document.
Posted on Nov 17, 2009
  • 85 Answers
SOURCE: Function keys F1 thru F12 don't work
Keyboard might have gone bad. Try hooking up a external keyboard and see if they work. If they don't then you have a motherboard issue. If they do then it is a keyboard issue. If you lucky it is just a keyboard then you can get one here for 20 bucks.
http://www.amazon.com/dp/B000MMCJQY/?tag=ricksphotograpag1-20
It is really easy to replace.
Posted on Apr 14, 2010
SOURCE: I have Compaq Presario CQ42
I just had exactly the same issue. I found the answer on the HP website, but to save you looking for it, here's what you do:
1) Go to the BIOS for your machine. You'll do this by interrupting the startup sequence. On my Presario CQ42, I had to press ESC while the machine was starting.
2) Once in the BIOS, use the right/left arrow keys to move to the System Configuration tab.
3) Use the up/down arrow keys to move to the Action Key setting (Enable/Disable) and change it from the current setting.
4) Save and exit the BIOS.
Once your laptop finishes the boot-up, the F1-F12 keys should function the way you were used to.
Posted on Aug 09, 2010
  • 643 Answers
SOURCE: Disable f1 through f12 keys?
You are not able to disable the function keys on any laptop
Posted on Oct 14, 2012
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
F12 function key doesn t work
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard.
They are located at the top of most keyboards and labeled "F1" through "F12."
Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond.
Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up.
Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key.
This key is used to toggle function-key support; when it is toggled on, the function keys will not work.
Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software.
If the key does not work, press the "F-Lock" key a second time, and test the keys again.
If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality.
Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.)
Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7
http://support.microsoft.com/kb/975741
Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard
http://support.microsoft.com/kb/894513
Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database.
Agree to the terms and conditions, then download the hotfix.
When the download is finished, run the downloaded file and follow the on-screen instructions.
You may need to restart your computer after the installation is complete.
Your function keys should now work properly.
Jul 14, 2013 | Dell Computers & Internet
My fn button wont work
Jun 27, 2013 | Packard Bell Computers & Internet
Why wont my fn button
Oct 14, 2012 | Gateway Computers & Internet
Touchpad not active
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 05, 2012 | Computers & Internet
My computer laptop model is Toshiba satellite P750. The FN key doesn't work. Nothing happen when i touch it.
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
http://www.ehow.com/list_5941452_laptop-keyboard-functions.html
Aug 27, 2011 | Computers & Internet
Touch pad is locked and dont know how to unlock it, the mousr is frozen
On the function keys at the top of the keyboard are the function keys (F1-F12) you should have one that has a picture of the touchpad on it (on my keyboard it is F7 yours may be on a different one). Hold down the control key and click on that function key.
Dec 28, 2010 | HP Compaq nc6000 Notebook
Mouse pad stopped working
If you are referring to the "touch pad" on Laptop/notebook, if the touchpad on your laptop is not working and is unresponsive, it's not broken, you or someone else has accidently deactivated it with the function key.
Then you can try this,
Most laptops (if not all) come with a function key. The function key is labelled "Fn" and usually stands out from the rest - either the "Fn" is in a different color or the key as a whole. The function key works in conjunction with other keys on the keyboard especially the ones in the top row marked "F1" to "F12". The combination of function key with these keys lets you perform various tasks quickly such as shutting the screen, putting the computer in sleep mode, switching the wireless connection on and off etc.
By keeping the function key pressed and then hitting one of the keys ("F1" to "F12"), activates a task. You can activate and deactivate the touchpad by using the function key with the "F8" key.
Hope it helps.
Dec 11, 2010 | Computers & Internet
Where is function key ?
Sir,
Definetly u want keyboard to press F8 for installating OS. Get another keyboard and connect it.
Thanks Good Luck
Sep 12, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
