Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio washer stops spinning with time left and doesn't restart
Cabrio washer pumps the water out and starts to spin but with about 9 to 11 min left in the spin cycle it stops and doesn't restart.I get a flashing lid lock at that point and have to disconnect power to reset and unlock the lid and clothes are still soaking wet,Frustrated HELP PLEASE!!!!
SOURCE: Cabrio top load flashing F51
F51 error is a rotor position sensor error.Its a very common error in carbrio washers.heres a website just for this error.Refer for the solution through it.
http://cabriof51error.blogspot.com/2008/01/my-f51-experience-day-7.html
Posted on Dec 15, 2008
  • 109 Answers
SOURCE: Whirlpoll cabrio wsaher won't drain
If this a electrical pump chk. to see if there is an in line fuse if not then take the hose loose to see if the impeller has any thing hung in it or it could be a bad spot on your timer
Posted on Aug 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Posted on Feb 12, 2010
  • 714 Answers
SOURCE: clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Posted on Feb 21, 2010
Testimonial: "thought it might be something simple like changing out a switch. Looks like we need a tech house call. Thanks"
  • 244 Answers
SOURCE: My Cabrio washer won't drain
There could be several things causing this problem. Have any small items gotten caught in the pump or between the basket and tub? You may be using a cycle with a low spin speed. If you need to remove excess water, select the Drain and Spin option. If the load is tightly packed it might cause the problem you're having. Are you using ONLY "HE" detergent? If so, be sure you're using the correct amount. To clean out residue from too much or wrong type of detergent select the "Rinse and Spin" option but do NOT add any detergent.
I hope this information helps. If it does, please rate my suggestion and its effectivness. Thanks!
Posted on Jun 03, 2011
I have a cabrio platinum washer. It is leaking water on the left side, it is starting to grind when it spins and it keeps stopping with a uL at about 8 min. into the spin cycle.
it sounds like the bearings have gone on the drum a service engineer is the only option as its complicated to remove the drum and fit new bearings and water seal eric
Dec 19, 2017 | Washing Machines
How do I fix my whirlpool cabrio washer is showing code sD
Ideally, you just run the washer without any detergent and it'll rinse out all the soap. Try that first. My Cabrio started doing that all the time, then stopped spinning out all the water. It had a host of problems and I opted to replace the washer. Hopefully the water rinse will fix the problem for you.
May 23, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
What can I do to get my WP Cabrio washer to drain & spin?
Your drain hose has to be higher than the water level in the tub, almost up to the top of the tub
Dec 30, 2011 | Whirlpool Cabrio WTW6600SBK
My Cabrio washer won't drain and spin. It says "LD" and consistently stops with 24 minutes left on the cycle. For a while if I would spin the basket a little it would work. Not that...
Jun 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Aug 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't do anything
try to remove as much water as possible ..wet vac will help pull unit out remove back cover lean washer forward on left bottom is drain pump remove 3 screws holding pump and clamps holding hoses on pump..on motor side of pump are 4 screws remove them noting location and orientation of pump body clean out ..ck impeller ..round white part with fins ..if it is not broke try turning it by hand should turn but with some resistance if free wheels replace pump if you found stuff in pump reinstall and ck
Aug 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
