I am getting air in my fuel line how can I fix?
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
SOURCE: My te 400 cxl weedeater
People replace fuel lines all the time as they deteriorate over time. This is a fuel delivery problem most likely and will require installing some new parts in the carburetor to fix. You can go with the cheaper diaghram kit or a full rebuild kit (includes the parts in the diaghram kit). This is a very, very common problem with these machines. If you feel you have to clean the carb at any time, only use non-flammable brake cleaner spray on it. Stronger cleaners and carb sprays can damage very sensitive internal parts. Don't use any high PSI air on it either as this has the same result as the strong cleaners. As far as an air line goes, these machines probably don't have one but they do have an air filter that needs to be checked or cleaned or replaced. They also have a fuel filter that is located on the end of the fuel supply line inside the fuel tank. Check that also.
