Question about Frigidaire Dryers
Www frigidaire com
Press start, e68 ,press again e4a ?
  • Frigidaire Master
  • 8,220 Answers
E-68 stuck button on keypad. Use warm towel to clean keypad and recenter buttons as suggested above.
Posted on May 02, 2013
4 Suggested Answers
SOURCE: Our dryer is beeping and
I found via a Google search that E68 means one of the keys is jammed. Looking at it, it was pretty obvious which one, so I pushed it in and re-centered it in its casing. That did the trick.
Posted on Jul 06, 2008
taran_2005
  • 10515 Answers
SOURCE: frigidaire dryer error E4A
This is this is the "program Timeout Fault". Meaning the drying time has exceeded program time for that cycle.Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, or bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 08, 2009
  • 1531 Answers
SOURCE: frigidaire electric dryer aeq7000es1 low heat only code e4a store
this is a door switch issue make sure the door switch is not broken
Posted on Sep 17, 2009
What is Frigidaire gallery dryer code e68
I appreciate your post, friend!
From what you have described your Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! -Matt
Feb 13, 2015 | Frigidaire Dryers
What does error code E68 mean?
Hello Friend, this is Z. Thank you for your question!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's perform Key Test to determine which button is at fault by entering "Function Test Mode". To perform the "Function Test Mode", doing the following:
Press and hold the START and CANCEL button at the same time for roughly 10 seconds. The stuck key should blink.
Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis.
Hope this helps!
Jul 27, 2014 | Frigidaire GLGQ2152ES Gas Dryer
What do i do when my fridgidair electric dryer displays error code e68
Good Afternoon Friend, this is Z. Thank you for your post!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's try entering a "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps!
May 22, 2014 | Electrolux Dryers
E68 on frigidaire dryer
Good Morning Randy, this is Z. Thank you for your post!
Typically error code E68 on your Frigidaire dryer can indicate one or two issues. First problem could be that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again. If button is free but the error code still exists, the electronic control will possibly need replacing. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, then you may have a faulty heating element. Best regards!
Apr 01, 2014 | Frigidaire FGHC2345LF Gallery 22.6 Cu. Ft....
ERROR CODE E68
Good Afternoon Robert, I am happy to assist you!
Typically error code E68 can indicate one or two issues. First problem could be that one of the keys of your dryer (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink.Carefully free the key and perform the test again. If button is free but the error code still exists, the electronic control will more than likely need replacing. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, the heating element may be faulty.
Dec 16, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly...
that's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
http://forum.appliancepartspros.com/dryer-repair/143380-frigidare-affinity-dryer-e68-error-code.html
Apr 06, 2011 | Dryers
I got an affinity dryer that threw a code of E4A and e68what is the solution?
Press the start pause button and the cancel button hold them together 30 seconds
Jun 05, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Error code E4A on my frigidaire affinity dryer
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Dec 02, 2008 | Frigidaire Dryers
Our dryer is beeping and is displaying an error code of E68. I hit Cancel to try to reset it, and it goes back to numbers (20 minutes or whatever), then after a couple seconds goes back to E68. I hit...
Jul 05, 2008 | Frigidaire Dryers
Dryers Logo
60 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
