Question about Air Tools & Compressors
Ingersoll rand T30 auto drain valve - Air Tools & Compressors
  • 76 Answers
SOURCE: Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
Posted on Jun 26, 2009
  • 98 Answers
SOURCE: I need the head bolts torque specs for an
With Graphite gaskets the torque is 34 lbs.
Posted on Jul 21, 2009
  • 205 Answers
SOURCE: T30
If air continously comes from the bottom of the pressure switch (bleeder valve) you have a bad tank check valve. The check valve is located on the receiver tank where the copper line from the compressor head goes to the tank. The brass hex between the copper line and the receiver tank is the check valve. Remove it after making sure all pressure has been bleed off the tank. Then you can inspect it. I recommend replacing it unless there is something obviously stuck in it that can be removed with no damage to the check valve. Another way to see if it is the check vale is to loosen the nut on the copper line at the HP head that goes to the receiver tank. If air continously blows from the copper line the check valve is leaking.
Posted on May 05, 2011
  • 33 Answers
SOURCE: ingersoll rand T30 wont shutoff and is dumping air out of the pressure relief valve , i replaced the relief valve and it just does the same thing when it reaches 60 p.s.i. the prv just starts to unlo
How old is the machine and when was the last time it was serviced, more specifically when was the separator element replaced?
The PRV you are talking about, im guessing you mean the one on the oil separator tank? (Where you put the oil in) If so, it sounds to me like the separator is blocked and needs replacing.
When the air is compressed, it goes into this tank (with the oil) it then comes out of there, through the separator element to separate the oil from the air, to prevent the oil going into your system.
If this gets blocked, the air is unable to go through the filter element and just keeps pressurising the separator tank, the PRV will release this pressure for safety.
Replace the element then you should be ok
Hope that helps
Posted on Aug 30, 2012
hunter19_46m
  • 7482 Answers
SOURCE: i have an ingersol rand 2420n5 t30 and i want to convert it from single phase to 3 phase any help thanks
Hi robles212
To convert your T-30 to single phase you will have to do one of two things.
1. Change the motor to a single phase motor
2. Buy and install a "Phase Converter" to convert 3 phase to single phase
Please rate me
Bud
Posted on Oct 09, 2012
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
How much oil for 2420N5
the price of t30 select is 6,000.00 pesos.
May 26, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
What size breaker for 5hp motor? Ingersoll Rand T30 242-5d 1988
If its a 220vlt compressor a 60 amp twin breaker is recommended. good luck!
Aug 08, 2011 | Ingersoll Rand Compressors 5-HP,...
What weight of lubrication do i use for this compressor...Ingersoll Rand TS4N5? And do I need to bleed the tank off before adding oil?
Yes it is always a good practice to bleed the tank down. there is a check valve in the top of the receiver tank that keeps air from blowing back Thur the system. However if it's leaking you will have pressure on the oil sump. As for type of oil use a 30 weight non detergent oil. Recommend using ir's t30 all season or another type made for air compressor's.
May 23, 2011 | Ingersoll Rand TS4N5 Ir Electric...
T30 model 2475N7.5 Ingersoll Rand will not bleed off head pressure when up to 145psi shuts down but will not start when at 95psi takes out breaker 50amp
Apr 29, 2011 | Ingersoll Rand - Rand Type - 30...
T30 lost pressure won't get over 100psi
I say head gasket leak or bad finger valve. Easy fix.
Sep 17, 2010 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
May 18, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Air Tools & Compressors Logo
29 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
