Question about Kenmore 3 Burner Charcoal/Gas Combo Grill Black
Kenmore charcoal and gas grill dual... burner problem
One burner will turn on and stay on high, but when we go to turn on extra burners, all the burners then go to low. Cannot keep the burners on high. Have tried the troubleshooting in the manual and that has not worked. This grill is very new so this does not make us happy
burzerko
  • 254 Answers
SOURCE: Kenmore 4 burner grill only lights 3 burners
Looks like your regulator is not venting properly to relieve the back pressure. The best thing you can do here is replace the regulator.
Posted on Jun 14, 2008
  • 4 Answers
SOURCE: Kenmore Elite 17680 gas grill
I had a local barbeque grill retailer ( a fireplace and barbeque store which did repairs) install a new one for me. I didn't want to mess with the venturi tubes and the exact length of the openings so it would work. I am glad I did as it works perfectly.
Posted on Jun 19, 2008
SOURCE: flame low on grill however the flame is high on burner
Had the same problem. Belive it or not i basically follow the turn on instructions. Disconnet the regulator, let it stand for five minutes, the reconnect and turn it on 1/4 and turn the burner that is at the end of the line. (in my case the is the first one on the left).
Posted on Feb 22, 2009
  • 43 Answers
SOURCE: Gas is not getting to the burners on my Sears Kenmore gas grill.
check if regulator fully screwed to tank, turn on tank,then last burner,should hear/smell gas. if not replace regulator
Posted on Jan 07, 2010
  • 43 Answers
SOURCE: Kenmore Gas Grill will turn off after three burners are on.
replace the gas regulator the hose connector to propaine tank
Posted on Jan 08, 2010
Troubleshooting nexgrill charcoal gas grill
did you replace the battery in the igniter?
less than 100 degrees indicates a safety has engaged, close gas valve, open burner valves.....wait 5 minutes. keep lid open, close burner valves, open gas valve until you hear the regulator click
turn on "ignition burner" and ignite (with switch or at specified port).
After this part is lit open other burners one at a time , waiting until each lights before opening the next.
Dec 07, 2013 | Nexgrill Charcoal and Gas Grill Combo
On a kenmore 5 burner grill when lighting the fourth burner all of the grill shuts down, regardless of which is the fourth burner?
Sounds like the pressure regulator is malfunctioning. Try disconnecting your gas line. Open/Close all burners then reconnecting gas. If propane, don't turn bottle off before burners. Always turn burners off first, then bottle. then bottle on before burners. This primes the regulator to the proper pressure.
Jan 09, 2012 | Kenmore Grilling
Used nexgrill for first time today. It's the combo gas and charcoal. Burners only lit like they are on the lowest setting when on high. Tried another propane tank and didn't make any difference.
The problem lies with opening the tank valve to quickly. This , then locks up the grill's regulator.
To solve this problem, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 22, 2011 | Nexgrill 720-0234 (LP)
Grill worked fine for almost a year but I recently used charcoal following the directions in the manual (and it worked great). However since using it (& it is long gone), if I turn grill on high,...
Kathleen, the ash and debris left from the charcoal clogged the burners and caused the flames to shoot back thru the venturi valves, which is causing the flames to reach the control knobs. For the most part. I would suspect that the control panel, the electronic ignition, control knobs, the gas manifold for the burners and the burners are now completely shot.
Now, you're at the stage of determining is it worth it, to replace all the parts (if you can find them) and repair the grill. Since you didn't mention who the manufacturer of the grill is and how long you've had it. I have no way to tell how much it's worth. But, if it were me, and the grill is at least 5 years old and it originally cost $600.00 or less, I'd seriously consider replacing the gas grill with a new one. And if you want to do some charcoal grilling, get a separate inexpensive charcoal grill and take good care of it. During the weekday evenings when you don;t have time for charcoal grill to preheat, use the gas grill. On weekends, use the charcoal grill if you like.
Hope this helped answer your question and ultimately help you make the right decision.
Apr 26, 2011 | Vidalia Grilling
Will not stay lit,I have a new gas tank and it light the first burner but will not light others and will not stay lit
Turn off the propane tank and disconnect the hose from the tank. Wait 5 minutes, reconnect the hose and turn the tank valve on very, very slowly, until it's completely open.
Now light each burner one a time and turn it to high. If the burners all light and the flames remain burning on high for more than a few minutes, you're back in business. Just remember to turn the tank valve on very, very slowly after turning it off each time.
If the above didn't solve the problem, are you sure you tank gas a significant amount of gas in it?
If that's the case (empty tank), when you replace it, do exactly what I said above when you connect a full tank to the grill hose.
Hope that solved your problem. Happy Grilling!
Feb 12, 2011 | Kenmore 882 sq. in. Cooking Area Gas Grill...
I have a brinkman gas grill model 810 8501 s and the searer will not stay burning unless I hold the knob in. As soon as I let go of the gas knob the searer goes out. Any ideas on how to fix?
First I have a couple of questions for your question on how ti fix your Brinkmann Gas Grill, Model 810-8501-S
1). Did you push the igniter for 3-5 seconds after you turned on the Sear Burner (remember, this needs to be done AFTER you've turned the control knob to HIGH).
2). Once the burner is lit, you then need to continue to PUSH & HOLD the control knob for another 30 seconds as this somehow seals the deal, thus this should solve the problem.
3). However, if this does NOT work, you may have a defective Sear Burner and the best thing to do is to contact the Customer Service Department over at Brinkmann:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Hope this helps!
Apr 06, 2010 | Brinkmann Stainless Steel All-In-One Gas...
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Jun 25, 2009 | Kenmore 16225 Grill
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Kenmore 3 Burner Charcoal/Gas Combo Grill Black Logo
70 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
