Riso Rp3700 won't print from computer
I normally produce masters by downloading document directly from PC (windows XP) using a USB to parallel port adapter cable, this has worked fine for 3 years. Last week I went print a new document, pressed print, the riso showed data processing with the small status indicator at the bottom of the riso control panel showing data-mapping. Then instead of the master process beginning (set to full auto) the status just went back to idle and nothing happens. The riso will generate a master ok using the scanner, but not from the computer interface. I have tried using a different pc and a different connecting cable and reinstalling printer drivers. I have tried with a different drum but no difference. the odd thing is there are no error codes generated, it just seems to be ignoring the data once it has been received.
We suffer the same issue. Have you find the solution?
Posted on Jul 28, 2014
Orbixx
  • 133 Answers
SOURCE: Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Posted on Sep 07, 2007
rjwharris
  • 102 Answers
SOURCE: Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 03, 2009
Fixe_You
  • 1800 Answers
SOURCE: printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Posted on Jun 05, 2009
  • 39 Answers
SOURCE: HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Posted on Feb 17, 2010
  • 3278 Answers
SOURCE: We have a Zebra 105SL connected to a Windows XP
Hello.
If there are no jobs in the print queue, be certain that your USB cable is snug.
If still a problem and there are jobs in the print queue, go to Printers and Faxes and delete your printer icon.
Note: Here's how to delete a printer icon in Windows 7:
1. Open Printers by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
2. Right-click the printer that you want to remove, and then click Delete.
If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer driver.
If still a problem, since you have already changed the USB port on your PC, the USB printer cable or the USB/parallel converter is probably faulty.
Also, test the printer by installing on another computer, if available.
Hope this helps.
Posted on Feb 17, 2011
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
My HP Deskjet 1120Cxi fails to print normal document and test printing. My computer operating system is window XP
Power on the machine, check front panel 'cartridge led' blinking? replace the cartridges,if 'paper led blinking' indicates paper jam check for paper jam.If printer comes in ready mode check in system drivers its is ready mode?.. if no check parallel cable if its good replace formatter..
Sep 06, 2011 | HP Deskjet 1120c InkJet Printer
How to connect to computer
The unit has a parallel port interface and is supported under Windows 95/98/Me, Windows NT 4.0/2000/XP . The drivers are available here: http://www.usa.canon.com/cusa/support/office/laser_facsimile/laser_class_2050_2050p_2060_2060p/laser_class_2060p?selectedName=Specifications#DriversAndSoftware . For the supported OS versions, download the drivers and then run the exe. If it extracts drivers, note the folder in which they are stored. Then launch the Add a Printer Wizard (Printers and Faxes in XP IIRC). If your computer doesn't have a parallel port, parallel to USB adapters do exist.
Neither Vista or Win7 Compatibility Center have the unit listed. The XP driver may work in Vista 32-bit with the compatibility mode on. For Win7 or Vista 64-bit, I'd suggest a second computer, a dual boot computer or a virtual computer with an older Windows OS. For the most setups, you'll need a licensed version of the Windows OS. (Virtual computer software include: Parallels, VMWare and Virtual PC.)
With Win7 Pro or Ultimate, you can download Virtual PC and XP mode from Microsoft for free, then install them in order. The printer will install normally into the XP virtual computer. However, files from the main computer will need to go onto optical media or an external drive in order to share them with the virtual computer for printing.
I hope this helps.
Jan 14, 2011 | Canon LaserClass 2060P Plain Paper Fax
Have a Risograph RP3700 that we have not used for a couple of
try cleaning the dry spot with WD40 or penetrating oil to melt down the ink
Apr 08, 2010 | Riso RZ220 Duplicator
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
I cannot get my Cannon D 880 to print from my computer. It will copy images, but get failure when I try to print. I have a USB connection, drivers are present it is plugged in and I cannot print. It says...
Communication Control
Communications with the PC are controlled using a bi-directional parallel interface (IEEE
std 1284-1994) or USB (Ver. 1.1). The communication protocols used for bi-directional
communications include: Nibble, ECP, Rapid Port.
Jul 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Slow printing of hp 3940 deskjet printer
You might be printing in a different mode...you can see it in the printing preferences tab(fastdraft, fastnormal, normal and best quality )... or are you directly connected to the printer? or in a LAN? try using a different usb port...
Aug 27, 2008 | Microsoft Windows XP Professional With...
309 people viewed this question
k24674
jasbo
jasbo
