Question about Sony RM-SS800 Remote Control
Sony remote control rm ss800 repair
Where are the screws to open remote located?
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
SOURCE: REMOTE CONTROLER RM-YDO10
remote controler car that uses gas
Posted on Apr 10, 2009
SOURCE: Code for Sony RM-V310A remote.
How do I program sony universal remote RM-V310A for a polaroid flat screen TV
Posted on Sep 09, 2009
  • 208 Answers
SOURCE: Unlock code from remote RM-X96.
http://www.fixya.com/support/t351405-sony_rm_x96
Posted on Mar 19, 2010
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Posted on Jan 02, 2011
My remote control HTT10-CRP which does not function any more.
you can open the case of you remote maybe there is 1 screw inside the battery holder or if there is no screw its only at clip type you can open it with the help of flat screw or knife...and then clean it with alcohol both the board and the rubber..
Sep 12, 2015 | Televison & Video
HOW CAN I OPEN UP A REMOTE CONTROL UNIT / MAGNAVOX - NC003UD TO CLEAN IT
Check inside the battery compartment and feel over any labels, there may be screws there that need to be removed before it will come apart. If no screws then there will be snap clips around the outer edges of the case, but inside so you don't know exactly where they are located. To get it apart use something like a credit card push it in between the 2 halves of the housing and slowly work it around, in and out until you find where the snaps are located, then use the card to carefully slide the snaps apart. Good luck...the snaps do tend to breal easily.
Aug 13, 2014 | Magnavox NC003 Remote Control NC003UD
Hi, My sony remote failed recently Model
There is some locks on its upper and lower case. You can locate it by its side slits.
Oct 06, 2013 | Televison & Video
How do you Open Sony rm-yd059
SONY RM-YD059 remote is easier to disassemble then other models. Slide battery cover open 1 inch or half open. Using a plastic toothpick or similar device pop cover using the groove. There are three sliding locks on each side. You will now see six screws holding halves together - remove. There are six more clips holding remote together. Starting at the top working towards the bottom, there are three per side, location of clips at red and blue buttons, at between 4&7 and 6&9 rows, and finally at muting and jump buttons. Voila - Happy cleaning. Note: directional ring is keyed with thin and fat tabs, fat tabs are positioned towards the bottom.
Feb 04, 2013 | Sony RM-YD059 Remote Control 148947911
HOW CAN I OPEN MY REMOTE CONTROL
Check the remote control for screws,remove all screws and take sharp edge knife prides all the remote sides plastics taps locks and force the remote to open up.
Nov 08, 2010 | Samsung BN59-00599A Remote Control
How do I remove the back of the remote control for a Sony TV? The model number is RM-ED002. I have located two small screws in the battery compartment but removing them doesn't seem to be enough to do the...
The two screws inside the battery compartment would not really hold the case together. Try using two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous.
Aug 22, 2010 | Sony RM-Y132 Remote Control
I have a Chamberlain garage door opener, Series CG40, 1/2 HP, #41A5021-1F. It opens just fine using the opener located on the wall. However, when I try to use the remote it does not work. I have installed...
Try programming this way. Hold the button down on your remote and then press and immediately release the smart/learn button. If this doesn't do it your remote may be bad. The wall control is hard wired and doesn't use the receiver that your remote does.
Oct 06, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Remote on/off relay stuck. How do I access it?
If this is the same model that I just worked on. (Red canister type vacuum) You have to remove the cord release pedal by prying or pulling it straight up with it lying on it's back. There will be two phillips screws. There is also two screws near the hinges of the door where the bag is located. Once you remove all 4 screws it will easily come apart.
May 19, 2009 | Kenmore Vacuums
How do i open logitech 785 remote?
After forcing my open, I found two screws more. Located at each side of the "activity" button - hidden beneath a the class covering the lcd-panel and framing keys. It is attached with double-sided tape. Rip it of - and your remote will look much better than mine...
Mar 11, 2009 | Logitech Harmony 785 LCD Remote Control
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
