Question about Garden
Mtd lawnflite 12 38
Battery is OK but when I turn on the ignition key. It's dead and does not start. Blades are disengaged.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
You didn't say it is not cranking but I assume its not. My Husqvarna has an inline fuse in the wiring harness when I found it it was blown I replaced it and was on my way
Posted on May 02, 2013
4 Suggested Answers
  • 202 Answers
SOURCE: Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Posted on Jan 28, 2010
  • 6468 Answers
SOURCE: lawnflite mtd 478sp 50/21 problem in starting but once started works great
try and clean out the carb
Posted on Apr 11, 2012
philwalker78
  • 608 Answers
SOURCE: I have a 17.5 HP Briggs and Stratton engine on a Yard Machines MTD riding mower. Starts fine and runs fine for about 10-15 minutes with blades engaged and then begins to sputter and die. I must keep
Hi, check that the fuel cap is venting and check the valve clearances. Regards Phil.
Posted on Jun 28, 2012
Lawnflite 630 ride on mower. Key to turn how do we start the engine?
hi,
did you lose your key? here is a link to buy one, they are generic so you might be able to go to a local lawnmower shop for that. if it wont start with the key check your safety switches at the blade control lever under the panel and under the seat. riding lawnmowers that sit out get rusted all over, look for rust and bad connections under the service panel and battery compartment, sand connections with sandpaper..
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/136-630-331-lawnflite-lawn-tractor-1986-forest-city/electrical-without-headlights
Jul 31, 2017 | Garden
Key will not work on ignition.
it has and oil safty switch on it you will have to push it to some flat ground to start it you will have to wait to start it let the oil settle down to level dont leave lawn mower on a hill it will happen every time
Aug 16, 2014 | M T D Products Mtd Gold 50"" 25 Hp Zero...
I have a 38" deck yard machines(MTD) lawn tractor. When I raise the lever to disengage the blades, the blades still keep turning. Does anyone know how to fix this problem?
If they are slow to stop,thats ok if they don't ever stop thats an issue,the brake shoes that drag on the top of the blade spindles are worn out or not adjusted correctly !
May 14, 2014 | Mtd Garden
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Husqvarna pto problem(?) disengaged blades to travel, would not engage after. Battery dead when checked after shutting off engine and wouldn't restart
Hi, first charge or replace the battery if necessary then check that the mower is charging the battery. The pto is probably fine but it needs battery voltage to engage. If the mower has stopped charging the battery may have had enough voltage to hold the pto in until you disengaged it but not enough to re engage it. Regards Phil.
Sep 06, 2012 | Garden
I have very recently purchased a 125/38" MTD. Not sure how old but appears in reasonable condition. I have used it for about total of 4 hours over past two weeks. Today I have a problem... the large...
My name is Dane and I am going to help you solve your problem. You said that the "Pulley" is loose when the blades are disengaged. I hope you meant that the belt is loose, because the pulley should never be loose. If it is loose, you should remove the pulley and make sure the KEY inside the center hole is still ok. Sometimes when the pulley gets loose it chews up the KEY and allows the pulley to turn on the crank. If the KEY is ok, just reinstall the pulley and tighten it.
I believe that your belt is probably just stretched and worn. The mower deck belt gets it's tension from lowering the mower deck. the lower the deck the tighter the belt. Just replace the belt. I hope I've helped! Thank you! Dane
Jan 01, 2011 | Mtd Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Jul 16, 2009 | Husqvarna Garden
Garden Logo
217 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
