2001 Honda Accord Logo
Posted on Mar 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FM Modulator Installing to 2001 Honda Accord need +12ACC power wi
How do I find which wire I can connect my Audiovox FM Modulator to for +12 acc power?
Anonymous
Level 2:
Sergeant:
  • Expert 140 Answers
  • Posted on Mar 15, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
140
Questions
Helped
84208
Points
553
Use a wire tester.. if ground the tester and poke the wires till you find a hot one.. then just simpley hook into that wire..good luck keith...
2009 Honda Accord 4 cylinder. 83-13 ,71-22, 61-23 code for it.
Question edited for clarity.
Question moved to model category from Miscellaneous.
Strange Japanese codes! Just run them through Google.
https://www.google.com/search?q=2009+Honda+Accord+4+cylinder.+83-13
Code 71 after SRS Reset - Honda Accord Forum
hondaaccordforum.com https://www.hondaaccordforum.com > forum > code-...
Oct 10, 2015 - The code 71-1 and 71-2 are for the driver's seat position sensor. 71-1 is for an open wire. 71-2 is for a short. The shop manual doesn't give .....
DTC 61-23: ABS Modulator-Control Unit Power Source Low Voltage. Attached is the diagnostic information. My experience has shown a bad battery can cause this code.
Mar 7, 2017
Honda Accord Code 61-23: Q&A on Dash Board Warning Light
1994 Accord: ac compressor does not come on in a 1994 Honda Acc...
I have one, prolly needs a new relay its on the end of some wires driver side by the radiator
Need to find switch power wire 2006 explorer for fm modulator
Have you tried looking for an empty cavity in the fuse panel? Usually there will be one or more in there, just stick probe in there, and if no power, try turning key on, and if it lights up (test light) or shows power , use it. make sure you fuse wire though.
Im trying to connect a FM modulator that connects straight into the antenna connector. Where is the antenna connection made at?
The antenna is plugged to the rear of the radio, either direct or on a trailing wire, depending on head unit.
A simpler version of a tv antenna connection, just a push fit with a coax cable.
4answers
Connect iPod to OEM radio for 2001 Honda Accord
They make adaptors that plug into the Ipod so you can play it through your radio.
Radio has no power not the fuse
There are (2) fuses. One behind the stereo attached to the positive wire and the other one is under the hood in the fuze box or under the steering wheel with the relays.
No constant Bat. for the radio. for a 1995 Honda civic.
Hi and welcome to FixYa,
Offhand on most car radio, the yellow wire should be connected to an always on B+12 source (such as the one connected to the + terminal of the battery); the red would be connected to an ACC B+12 such as the a wire from the IGN switch and of course the black to the GND. A fuse would be inline on either or both the yellow and red. The fuse holder would look like a tubular lump along the wiring sometimes black or translucent. In some instances, there would be a fuse holder below the connector at the rear of the radio. To determine always on 12 and ACC 12, a voltmeter would come in handy.
Good luck and Thank you for using FixYa.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
