Can you change channel with remote at receiver end?
    Top Expert:
  • Televison & ... Master
  • 75,304 Answers
Yes. It can.
Posted on May 02, 2013
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
TV will not display picture or sound except for 1 station which appears to be 440. I can't change the channel either at the dials or remote. The display says EAS.
DONT USE the remote that came with your TV
use the buttons on the box to change the channel. did the channel change?
usually when someone only has one channel its because they are changing the tv channel not the cable box channel
think of it like this:
the TV is a monitor and should always be on the same channel (3, 4, hdmi, or whatever) its actually the box that tunes and the tv always stays on the same channel.
so if you change the tv channel you are no longer watching the output of the cable box.
USE the remote supplied by your cable provider
Aug 06, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
How to change input on tv without a remote
Which TV do you have? Some will have an Input or Source button on the front panel. A few will have an option to change the source from the menu. Both of these options require the front panel lock to be inactive.
A few older TVs allowed you to find the A/V input by pressing Channel Down on the front panel buttons until you passed channel 2 (or Channel Up until you nearly reached Channel 2). This option wouldn't work if the A/V inputs had been deleted when someone minimized going through unused channels.
If the Source or Input button was only available on the remote, you will need a universal remote that includes this feature. These cost a bit more than the lowest end remotes. Then you will have to try all of the codes to find the one that makes the Source button work with your TV. (Several codes may work for On/Off but not the change input.) The Universal remotes that can be programmed from a computer (USB connection) will be the easiest to set up. Remotes.com may have a replacement original or substitute remote for your TV that should work for all of the TV functions.
I hope this helps. Please add a comment with the TV make and model for specific options for your particular TV.
(low end TVs usually only had the Source/Input button on the remote.)
May 12, 2012 | Sony Televison & Video
Channel lock is stuck on
May 28, 2011 | Televison & Video
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
Can not change channel with my new remote on my bell receiver
There could be a few different things causing the problem, but beginning troubleshooting would consist of the basic questions such as, are there fresh batteries in the remote and is the remote in the correct "Mode?" In order to change the satellite channels- remote needs to be in "SAT," mode, you can verify what mode the remote is in by attempting to change channels, or by simply pressing any button on the remote such as channel up or down - if the remote is in fact in sat mode the "SAT" button in the upper left hand corner of the remote will light up- this will allow you to confirm the remote is in the correct mode to allow you to successfully change channels. Also another potential issue is when you started experiencing these remote problems- has anything changed? Did you perhaps move the receiver to a different/new location? The sensor on the top of the remote and the front panel of the receiver need to have a clear path of signal in order to work, sometimes (usually rare) if the receiver is enclosed within a cabinet with glass doors this can cause an issue as well. Hope one of these tips helps; feel free to contact me directly if you need any further assistance.
-Kirstie DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
Can't change the channels
Whenever a remote is not working to change channels thefirst thing to check is the batteries. Even if some buttons on the remote areworking, it is possible that low batteries are the cause of not being able tochange the channel. Once the remote has fresh batteries, you'll want to makesure that the remote is in the correct mode. This can be done simply bypressing the 'SAT' button and it should light up. The next thing to do isre-address the remote to the receiver. First, press the 'system info' button onthe receiver (or access system info through the menu). Once the system infoscreen is showing on the TV press the 'SAT' button once and release then pressthe record button. The remote should then be working with the receiver.
Kaia S
DISH Network
May 20, 2010 | DISH Network IR Remote Control
Dish remote wont change channels
make shure it is turned on the sat setting
Oct 05, 2009 | DISH Network IR Remote Control
RM-AV2100
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Dec 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
