Question about Koss CS-95 Consumer Headset
Koss CS-95 Headset Mic Not Working with MacBook Laptop
Headset works fine (previously with PC), but mic is non functioning with MacBook. In Mac System Preferences, there seems to be no other option to "recognize" the Koss set other than a "Line In" option. Even that doesn't work. Do I need "driver" software loaded for this headset to get my Mac to "recognize" it? Thanks, Robert (MrDad)
4 Suggested Answers
SOURCE:
SOURCE: My mic aint working
my mic wont work when im trying to talk to someone on intant message but it works when i use my speech recignition program. im sure i spelled recig wrong
Posted on Nov 08, 2008
SOURCE: mic on ps3 headset does not work
how do you pair it ... my light wont turn purple...
Posted on Dec 27, 2009
  • 96 Answers
SOURCE: I am using a Koss
Windows isn't directing sound to the headset plug. This can be changed under control panel sound.
Sometimes it will asign itself if you turn on the computer with the headset already plugged in.
Also check the settings under all programs --- accessories -- entertainment -- volume control
and make sure the volume isnt too low or muted for the device.
Posted on May 16, 2011
The Mic is not working
right click on the speaker icon and make sure external mic is set up. One time I had to use my internal mic to record stuff it was a pain.
Play back devices
Recording Devices
Jan 28, 2014 | Frisby Computer PC Laptop Headphones...
LG Headset can pair with PC and I can hear but the mic is not working
I have this sale problem. I am using a rocketfish micro dongle to connect my LG tone to my PC and I can hear fine. However, when I set the bluetooth mic to default, I only hear these random blips and pings and it shows nothing received in the audio bar.
Feb 04, 2013 | LG hbs-730 Tone Stereo Bluetooth Headset
Trust headset HS2900 suitable for apple macbook?
On the MacBook there is no microphone port, if you look closely, it is not a microphone plug, it is a line in plug. Line in cannot record sounds from a microphone without amplification. What I would recommend doing is purchasing this adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16812186035&cm_re=usb_audio-_-12-186-035-_-Product- With this adapter, you plug your headset and mic into it and then it plugs into the USB port on your MacBook. Then you can just unplug it from the USB port when you are done.
Feb 09, 2010 | Apple MacBook PC Notebook
Toshiba satelite isn't recognizing that the
Have you tried using a different mic? If its a cheap mic It may have very well just quit working(or never worked).
Is it a new laptop? If not, any previous issues/problems?
"Apparently" the drivers are updated? "Apparently" isn't exactly a good term to use when it comes to something like drivers. Its either: Yes, they are or No, they are not. Make sure they are first.
To test if the mic is/isn't working go to Control Panel> Sounds and Audio Devices>Advanced Button(Bring up the Mixer)>Properties>Make sure Mic is checked in the list. Go back to the mixer, and un-mute the mic and slide the volume bar all the way if it isn't already. Now talk into the mic, is it playing threw the speakers? Yes? No?
From what you've provided I would guess its just a bad/broke mic. I'd suggest investing in something better, like a headset with the mic built in(as you'll probably need one at some point anyways).
Oct 22, 2009 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
What type of headset do I need?
You're laptop has already the mic, so need for you to buy headset with mic. But, make sure that your laptop built in mic is still working.
Regards,
Jeep Brainy
Sep 20, 2009 | Computers & Internet
Mic doesn't work.
I am guessing that if you have tried all of that and it is not working then maybe it just shorted out. Try wriggling it around to see if it goes in and out. If so then there is your problem. Shorts in wiring are tricky to fix but i would suggest just getting a new device.
Apr 28, 2009 | Audio Players & Recorders
My mic aint working
most likely a broken wire inside. it's dead imo.
Apr 14, 2008 | Koss SB45 Professional Headset
Driver headphones
Do you mean a software driver? There are no drivers needed to connect to the PC or MAC. Do you mean the speaker itself?
Oct 28, 2007 | Computers & Internet
Mokrophone is not working
Found the problem... What Apple has is a line-in port...it requires a pre-amp to boost the signal of your mic. A PC likely has a mic-in port.
They're different ports...very similar but they accept different levels of input. Apple likely wants you to use their built-in mic for mic use and the line-in port for line-level audio sources.
Thsi appears to be our solution... Griffin iMic / USB Audio Interface
What a pain.
Oct 20, 2007 | Sennheiser BINAURAL HEADSET :unitsize...
Recording to Cubase
does the laptop have a built in mic.??? if not your going to need a mic. also, make shure the mic is connected to the rite jack, there should be three, and only one works... Good luck!
Sep 20, 2006 | Apple MacBook Pro PC Notebook
Koss CS-95 Consumer Headset Logo
412 people viewed this question
Top Koss Radio Communications Experts
 Grubhead
Grubhead
Ekse
Michial Gueffroy
Are you a Koss Radio Communication Expert? Answer questions, earn points and help others
