Question about GE JKP27 Electric Double Oven
Replacement Oven control (WB27T10264) installation
I was a replacement oven control. It does not match up logically with the original. Orginal is control isWB27K5299 Replacementcontrol is WB27T10264 The oven is JKP27 The socket for the ribbon cable in the new controller accomodates a wider ribbon cable and is oriented horizontally as opposed to vertical on the board. The individual wires don't match up with wiring docs circulating on the internet. Those docs reference connections labeled NO and COM which are not on the new board. It looks like word NO may have been written over the OVL2 connection. Hard to tell. Has anyone solved this ? This is supposed to be the correct replacement part. Outside of many guesses I don't see how anyone (including a technician) could install the thing.
Powerman
  • 68 Answers
SOURCE: Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Posted on Oct 31, 2008
Powerman
  • 68 Answers
SOURCE: jrp24bow3bb electric double oven control panel.
Hi rhonm,
You should have found a connection diagram in the top of the oven. If you didn't, call GE at the following number and they will send you one. 1-800-626-2005
It would be very difficult for any one to make a recommendation without seeing the oven or part. Are there one or two gray wires? My first guess is that they sent you the wrong part. See photo for typical double oven ERC.
Regards,
Powerman
Posted on Dec 07, 2008
  • 973 Answers
SOURCE: The LED display on my GE JTP56 electric wall oven
It sounds like a defective Control Board, return it or exchange it for another one.
Posted on Jun 13, 2010
SOURCE: I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Posted on Jun 14, 2010
SOURCE: I have a GE JKP15WOW1WW. I am replacing the
I have the schematic in my hand,
I just id this last night
L1,AUX1, L1 are the 3 black wires
OVL1,N are the white wires
green is the ground last terminal on right ,if your facing it
OVL2 is the brown white striped wire
Posted on Oct 01, 2010
The door frame on the microwave is cracked. Can I buy a replacement?
Yes, but the replacement door may cost as much as a new microwave oven. Not sure if it's logical to replace just the door.
May 12, 2015 | GE JKP85 Electric Double Oven
Jenn Air SVD48600
One of the relay boards is a downdraft relay board....I would be suspecting the main clock assembly as it is the one that shuts down and controls everything. This might also increase the fan speed randomly, turn it on at random temperatures etc., You have to get a new board. You can find it here
http://www.affordableappliance.com
Feb 27, 2008 | Ovens
Tip
Repairing an (F2 E0 or F2 E1 error code) Failed Whirlpool Builtin Oven Keypad...
A replacement touchpad is now available from Ledgestone Technologies to replace various membrane keypad switches that are not available from the OEM.
These are in stock and can be shipped today from fixyourboard.
Find the full list of applicable models here:
Introducing the Ledgestone Technologies Touchpad
Step 1. Remove Original Plastic Bezel
BE SURE TO REMOVE POWER TO OVEN FIRST!
You are going to re-use the original plastic bezel. Remove the panel from your oven that contains the keypad and control board. Uplug the keypad from the control board. Remove the control board from the panel (4 screws).
Step 2. Remove Original Touchpad Membrane
With a heat gun, lightly heat the original keypad from the back of the panel. This will soften the adhesive. Gently but firmly push the old keypad off the bezel by pushing from the back of the panel on the keypad window. Carefully remove the original keypad membrane element. Most of the original adhesive should pull off with the keypad. Rub off any remaining adhesive.
Step 3. Install New Ledgestone Touchpad
Remove adhesive backing paper from the Ledgestone Technologies KP1308A1 Replacement Touchpad Membrane. Align and adhere new touchpad to recess in plastic bezel. Below are examples of black on black and gray on white. Gray also looks good on bisque or almond.
Step 4. Re-install Bezel on Oven
Re-attach control board to bezel, plug-in new keypad. Re-attach bezel to oven frame. Done!
Applicable Models
RBD276PDB10 RBD276PDB11 RBD276PDB12 RBD276PDB7 RBD276PDB8 RBD276PDB9 RBD276PDQ10 RBD276PDQ11 RBD276PDQ12 RBD276PDQ7 RBD276PDQ8 RBD276PDQ9 RBD306PDB10 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDB14 RBD306PDB15 RBD306PDB7 RBD306PDB8 RBD306PDB9 RBD306PDQ10 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDQ14 RBD306PDQ15 RBD306PDQ7 RBD306PDQ8 RBD306PDQ9 RBD306PDT11 RBD306PDT12 RBD306PDT13 RBD306PDT14 RBD306PDT15 RBD306PDZ10 RBD306PDZ7 RBD306PDZ8 RBD306PDZ9
Original Whirlpool Touchpad Part Numbers
4451969 4451970 4451975 4451976 4451977 8300431 8300432 8300437 8300438 8300439 8300640
on Aug 17, 2015 | Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Re: how to recalibrate oven so the temperature in the oven matches oven display.
This is controlled by the thermostat. You will need to look into a replacement.
Apr 08, 2014 | Frigidaire Ovens
Have a Whirlpool Gold dbl. oven. Last Fri. night oven started beeping and display the E0F2 code. Turned off brk'r till next a.m., turned on only to have in a rolling sequence going from 350 upper oven...
Good Evening!
Do you have the full model number of your appliance? Do all of the buttons beep when pressed? If not, unfortunately, the touchpad on your unit may have failed again. An E0-F2 is a stuck key error. The only way to fix this issue would be to replace your touchpad. Your more than welcome to send in your touchpad and control board for evaluation and testing. Contact us for more information info@fixyourboard.com. We also have replacement touchpads for your oven if the original OEM part is discontinued.
Ledgestone Technologies Keypad and Ribbon Cable Installation
May 25, 2017 | Whirlpool GBD277PD Electric Double Oven
My digital display is not working on my Whirlpool Super Capacity 465
Your problem is most likely the main circuit board for the control panel. That is really the brains for the oven. Ovens are funny things to put electronics in. Electronics do not like heat and what use is an oven that doesn't get hot. I have replaced several of these boards in the recent past and that is what you are most probably going to need to do. Should be an easy replacement. Just be careful removing and replacing the connectors. Some are very fragile (not a good thing to engineer in for a consumer product). I would recommend that you get the model number from the door tag and call one of the appliance replacement companies or Sears for a replacement control board. I would remove the original and make sure that you are ordering the right part number. Manufacturers have a bad habit of switching control boards mid production year, so you could end up with a replacement that will not work.
Aug 02, 2012 | Whirlpool Ovens
I NEED A CONTROL BOARD FOR A GE OVEN JRP15WOW4WW
The part# for that is WB27T10264 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
appliancepartspros.com
repairclinic.com
apdepot.com
Gene
Aug 13, 2011 | GE JKP15 Electric Single Oven
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
Ovens Logo
167 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
