Question about Pioneer VSX-C302 5.1 Channels Receiver
Pioneer dvd/cd reiciever. model - xv/dv303
I have sony trinitron and the above dvd. now i cannot set up dvd to tv. also dvd has sorround sound and has no scart lead to go into only sockets for L/R 6 of them. my tv model is sony kv-32fx65 u, i want to be able to lidtn to surround on both tv and dvd, please help as soon as. thanx, natral
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Pioneer XV-DV303 (DVD/CD Receiver) When playing
I imagine ANY audio source would do the same if played loudly enough.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 16, 2011
taran_2005
  • 10515 Answers
SOURCE: pioneer dvd/cd receiver xv-dv303 When
Try unplugging the unit for 60 minutes, then plug back in and try it again. This will reset the processor and hopefully the unit will operate normally. Check all the speaker wiring for shorts, make sure they're also not touching the chassis of the receiver, or are not otherwise pinched or frayed. If all looks well, try disconnecting all the speakers and cycle the power off, then on again.
If it powers up, try connecting the speakers one at a time until one of them shuts the receiver down. Check this speaker with a multi-meter and make sure it is reading between 4-8 ohms.
If not, the speaker may be blown and is causing the receiver to see a short and therefore power down.
If the unit shuts down with no speaker load connected, or fails to power up, then it likely has a bad output transistor, or capacitor and is in need of service. I can send you the contact info for a Service Center near you if you'd like.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 28, 2011
My Pioneer XV-DV282AP home theatre has no Audio output. Every time I put the volume up/down, it keeps on saying HDMI/TV Audio. It only works with an HDMI cable using the speaker from the Television.
The system is set up to output sound through HDMI to the TV. You can change the setting so the sound is sent to the speakers. The process for changing the HDMI output setting is in page 41 of the manual. You want to choose the AMPsetting. I have included a link to the manual and copied the text below.
1. Press SHIFT+SETUP.
2. Use ?/? to select HDMI SET then press
ENTER.
3. Use ?/? to choose HDMI MODE then
press ENTER.
4. Use ?/? to choose the setting you want
then press ENTER.
• AMP - Output Audio sound of the DVD/CD
and USB function signal from this system
• TV - Output Audio sound of the DVD/CD
and USB function signal from a TV or flat
screen TV.
http://www.manualslib.com/manual/130342/Pioneer-S-Dv180.html?page=41#manual
Jun 10, 2015 | Pioneer Audio Players & Recorders
CD/DVD player won't read discs
Firstly you need to get a Lens Cleaning Kit from KMart, BigW or your countries version of a Supermarket. Use that on the DVD player and then check all your discs for dust and dirt. Clean the discs by lightly wiping from the inside to the outside in a circular motion.
Next step if that doesn't solve the problem would be to take the cover off ( ensure unit is off and unplugged from the power source) and check if the lens is not covered with dust, lint, fluff etc. If covered wipe lightly.
NEVER LOOK DIRECTLY AT THE LENS LIGHT
Feb 18, 2010 | Pioneer Televison & Video
Have got pioneer xv-dv303 dvd/cd receiver.It does not play any dvd and cd these days. I think it needs the firmware update. How can do that.
You need:
PDA w/Palm OS 3.0 or later
OmniRemote Pro V2.02 (http://www.pacificneotek.com/)
Sony Clie peg-SL10
Type in (or transfer) the memo below to your PDA.
As a memo you can import it into OmniRemote with this menu command:
Advanced-->Databases-->Import category
When done, point your PDA towards your DV-454, put OmniRemote in TV-mode and press 0 (Zero)
That's it!!
Some stores charge $35 for this! All I ask is a small donation ($1 or more if you like) to help my site!
Memo (Name: Category-TV):
Category-TV
Button name-Enter
0000 0067 0000 0000
Button name-0
0000 0069 0049 0000 0154 00AA 001E 0032 0019 003C 001E 000F 0019 000F 001E 000A 001E 0037 0014 0005 0005 000A 001E 0037 001E 000A 001E 000F 0014 003C 001E 0037 001E 0037 0014 0014 001E 0037 0014 0014 001E 0037 001E 000A 001E 000A 001E 0037 001E 0037 001E 000A 001E 000A 0019 003C 001E 000F 0014 003C 001E 0037 001E 000A 001E 000F 0014 0005 0005 0032 001E 0037 001E 000A 001E 045B 0154 00AA 001E 0032 001E 0037 001E 0037 001E 0037 0019 000F 001E 0037 0014 0014 001E 0037 0014 0014 001E 000A 001E 000F 0019 000F 001E 0037 0019 000F 001E 0037 0019 000F 001E 0037 0014 0014 001E 0037 001E 0032 001E 000F 001E 0032 001E 000F 0014 0005 0005 0037 0019 000F 001E 0037 0019 000F 0014 0005 0005 000A 001E 0037 001E 000A 001E 0037 001E 0037 0014 0465 014F 0000
Button name-7
0000 0067 0000 0000
Button name-8
0000 0067 0000 0000
Button name-9
0000 0067 0000 0000
Button name-4
0000 0067 0000 0000
Button name-5
0000 0067 0000 0000
Button name-6
0000 0067 0000 0000
Button name-1
0000 0067 0000 0000
Button name-2
0000 0067 0000 0000
Button name-3
0000 0067 0000 0000
Button name-Channel up
0000 0067 0000 0000
Button name-Channel dn
0000 0067 0000 0000
Button name-Last
0000 0067 0000 0000
Button name-Volume up
0000 0067 0000 0000
Button name-Volume dn
0000 0067 0000 0000
Button name-Mute
0000 0067 0000 0000
Button name-Power
0000 0067 0000 0000
Button name-Favorite
0000 0067 0000 000
Feb 11, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
I have a pioneer DVD/CD receiver XV-DV303 and I played deck music through the system. However, I think it over heated and shorted, as the sound cut completely and I have not been abkle to turn it on for 2...
Output devices have failed, due to excess heat, volume level, or some type of input overload. This is not to say that the components could themselves have a fault due to internal stresses. It's shop time...accordianman
May 10, 2008 | Televison & Video
DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
Sep 08, 2007 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
Pioneer VSX-C302 5.1 Channels Receiver Logo
442 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
