Question about GE Profile 30" Self-Cleaning Drop-In Electric Range - True White
Kenmore 45461 panel beeps F5
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
Self cleaning keeps popping up beeping with F5
Hello,the F5 beeping is all about the Push button stuck.
Check for the binding of Push button and control panel glass.If OK,replace the touch panel.
Thanks
Jun 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Roper 45461 f5 error code
Hello- Bad news- the control has failed. Replacement boards are 150-250$ Installation about 100$.Please reply if this info helps- have more if needed- Thanks- ED
Mar 03, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Oven door locked E1 F5
hi..
The manual says F5 means "failed circuit in control". This means that the control panel is burned out.. So just replace this..
Thank u
rate me!!
Jul 25, 2009 | Kenmore Ovens
Flashes code F3 (sometimes f5) and beeps
OK. I found the manual your looking at. The serial number label is located at the back left and underneath the cook-top. I am not certain if you can see it by removing the burner and tray, but if not, you can "pop the top" by grasping along the seam at the front of the unit, just above the door. DISCONNECT POWER FIRST!
And, in doing some more looking around, if you have reset the controller using the instructions from the manual (which includes disconnecting power for about an hour), then odds are pretty high it's either the temperature sensor, or the controller. The sensor is cheap, the controller more expensive, but odds are better it's the controller. Replace, or have, both replaced. You'll have essentially a new oven when you do this.
Jan 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range F5 and F3 warnings
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 13, 2008 | Kenmore 30169 Electric Single Oven
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
GE Profile 30" Self-Cleaning Drop-In Electric Range - True White Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
