Question about Karcher Garden
Won't start after running fine
I went though all the manual's troubeshooting. It just stopped working after I had to change electric outlets. What is broken?
  • Karcher Master
  • 17,328 Answers
You tested it on other outlets? Check the motor for reset button?
Posted on May 06, 2013
Won't run
Check operation of the interlock switch for the condensate collector. I had a dehumidifier that would not run unless the collector was shoved in and held in place
Dec 29, 2012 | LG LHD65EBL Dehumidifier
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
When you push start button nothing happens
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Sep 28, 2012 | Washing Machines
Machine won't start up...How can I reset it? Have unplugged it and plugged it back in and nothing happens. The electricity went off the last time I was making bread, but seemed to pick up where it left...
Hello Deborah...
Only to follow the INTRUCTIONS...
Leave it set for a while...
Make sure you OUTLET has power...
Check the cord for any damage...(?)
Then (as the manual urges) contact customer service.
Read here...
Breadman TR520 Instruction Manual Recipe Manual Display Information
Hope this does it...
Carnac the Magnificent
Feb 15, 2018 | Breadman TR520 Bread Maker
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have an Ingersoll Rand 2545 Electric Air Compressor and since the summer started it runs all day(won't shut off). At night it seems to cycle correctly but when the heat builds up during the day...
I don't know if your unit is exposed to the direct sun light if it is I suggest you create some shade , or if this this unit is enclosed is not getting enough air flow to keep cool.
( this air flow helps to stabilized the sensor that stop and start the compressor )
Sep 26, 2017 | Ingersoll Rand 2545/7100 Electric Air...
My 2001 Saturn SL1 with 140 miles won't start. It was running fine then went out to start it this morning and nothing. When I try to start it the clock on the dashboard resets. Headlights won't...
put a drop tester across the battery its flat for whatever reason or had its life so try charging it with a trickle chearger for a couple of days and if still no start then renew it
May 21, 2011 | 2001 Saturn SL
Garden Logo
162 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
