Question about Saeco Magic Comfort Plus Espresso Machine
Descale prompt stays on after descaling?
I descaled the machine when prompted, but the prompt won't go away. Does that mean I need to do it again? Or is there a way to get rid of it until next descale required?
  • 3 Answers
In the menu just after descal go to signal descal then press enter and reset the counter.
Posted on May 02, 2013
5 Suggested Answers
mirran
  • 515 Answers
SOURCE: What Descale sign means
Start the descaling and follow the instruction the machine give you.
Best regards
/Mirran
Posted on Sep 07, 2008
  • 20 Answers
SOURCE: descaling a Saeco InCanto deluxe
Press and hold the descale button(lower right), it will light up.Then you can start the process. The machine will prompt the next step when the solution in the tank is used up. Have a go.
Posted on Dec 23, 2009
espressonist
  • 1711 Answers
SOURCE: how to descale machine talea giro plus
Many times if you perform once more descale the problem can be solved so here is a video that can help to repeat the descale
Posted on Aug 29, 2012
SOURCE: talea giro descale already done but red led of descale has not gone
I was told by tech that if you hold the water button in for a few seconds then this resets. It depends on what kind of water you use too. If you use filtered or spring water then you don't need to descale it as often and you can override this by above method. Hope that helps.
Posted on Oct 03, 2012
How to Download
For example, go to www.download.com type avast antivirus, scroll down the page until you locate it, click on download, if are running XP you will be prompted near the top browser, click the bar, and click do you won't to run the file, the download will commence until finished, then click run and follow the prompts. Now if you have windows 7 click on download it will prompt you at the bottom, click run and follow as prompted.
Mar 23, 2012 | Computers & Internet
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Needs descaling, I don't have the manual, what is the procedure??
Hi Auto descale: To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrows on the to scroll up until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the open the steam knob again. Let it quit on its own. Refill tank again and prime the machine and your ready. Exit "Descale mode and scroll down to "Reset descale", press the enter button and chose "Yes", then exit and your ready for the next time.
Jul 21, 2011 | Saeco Royal Professional Espresso Machine
How do I decalcify my coffee machine?
Hi Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll up until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say, "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to "Signal Descale" and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Jun 07, 2011 | Saeco Royal Cappuccino Espresso Machine
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I have decalcified my Gaggia Synccrony twice using a product from the grocery store called dip-it and it is still saying to decalcify the machine
First of all - Dip-it is a detergent to remove rancid oils from coffee cups and coffee makers. That is not the same thing as a decalcifier or descaler. Dip-it was never meant to go through your boiler and pump and valves and all the other parts inside your Gaggia.
I'm quite sure that if you read the Gaggia manual it will tell you to use a special descaler such as Dezcal or Durgol.
Some people say use white vinegar - the manual specifically says not to use vinegar.
The machine is pretty expensive - it's worth buying the right product to descale it.
The manual should walk you through the steps to descale which will clear the error message once all the steps have been completed. I don't own that specific model, but typically you add the dezcal powder to very warm water in the water tank. Then start the descale process which will prompt you to open the steam valve and pump some water through the steam valve (into a container you place under the steam wand to catch it). Typically it will cycle a little water then pause for several minutes while the descaler disolves the calcium build up in the boiler - then it will pump a little more though and then wait etc. etc. Depending on your machine it may pump water out the coffee spout as well as out the steam wand. If so, the machine should prompt you to tell you to open and close the steam valve.
After it has run all the chemical through the machine (usually after it has emptied the tank) it should then prompt you to rinse. You remove the tank and wash it out and fill it with clean drinking water and then let the machine continue on the rinse cycle which will pump all the clean water through the unit. So you need to be on hand to catch all that water and dump it in the sink. When you are all done, run a few blank shots and make sure the water tastes like clean drinking water. The descaler is mostly citrix acid (like lemon juice) so if the water tastes sour like lemons then it isn't completly rinsed yet and you may want to pump more fresh water through the machine (pull blank shots or pump hot water through the steam wand) until it is fully rinsed.
Once the machine completes the rinse cycle it should stop prompting you that you need to descale.
Oct 11, 2010 | Gaggia Titanium Espresso Machine
Red light is on (looks like an M) and I don't know why??
It means time to descale , however if you want to get rid of it, just press and hold the water button until it goes off.
To descale..fill the container with descaler and let water goes through the system by openning the valve and catch the descaler with a container. Turn off the machine a few minutes and start the process all over again for 1/2 hr, and finally with water to wash the system.(donot want to heat up the descaler too much)
May 27, 2010 | Saeco Odea Giro Plus Coffee Maker
Descaling a Saeco InCanto deluxe
Apr 04, 2009 | Saeco INCANTO DELUXE Espresso Machine
Descaling
I had this happen once and had to put it through the descale process again. Just put more water in the tank, try it again and see what happens.
Winesnob
Apr 23, 2007 | Miele CVA615 Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
416 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
