Question about Andis Dog Clippers - AGP Super 2-Speed purple
Andis Clippers not locking
I have replaced the blade drive. I just bought my clippers and they will not lock my blades into place. When I put them on I can still take them off by simply pushing backwards on the blade. What is wrong with them? How can I fix them? I need to use them for grooming academy, so I need them working ASAP!
  • 193 Answers
Make sure you are putting the blades on with the clippers running otherwise the blade will not locate correctly. Failing that it could b e a broken 'latch' AGC
Posted on Jun 06, 2015
Problems Andis AGC 2
Sounds like it's time to replace the clippers with something much better.
Apr 24, 2013 | Andis Agc Super 2-speed Clipper...
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
Clippers stopped clipping. I changed to a new blade but it didnt help. I took the clippers apart and put in a new holder for the clippers. I put the clippers back together and although they clip a little...
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Jul 05, 2011 | Andis AGC2 Hair Trimmer
Brand new blades #10 in perticular leave stripes
hi, new blades are not the answer try replacing the blade drive assembly which is located at the drive end of the clipper and goes from side to side, as the clippers are used this part will gradually wear in width thus not moving the cutter far enough to complete a cut this will produce snagging in smaller blades and tram lines in larger blades like 7, 5, 4 and 3's. All Clipper Parts are available for these clipper repairs.
May 29, 2010 | Andis 01690 Hair Trimmer
I took apart my andis hair clippers and now i can not get the little blade to stay in place is there a trick to this?
i took apart my andis t-outliner & i dont know where to put the oval shape silver pice
May 20, 2010 | Andis 04603 Hair Trimmer
I have andis AGC 2 dog clippers. I have having trouble taking off/removing the blade that came with the clippers. The under portion of the blade assembly seems to be stuck. Also, since I'm having so...
Ok you need to locate the Latch which holds the blades into place. There should be a black piece of metal at the rear end of the clipper blade whilst on the clippers, simply push this in towards the blade and at the same time pull the front edge of the blade away from the clipper to release this should simply pull off in a forward direction.
Fitting is easier slide a blade onto the tongue of the Hinge Assembly and pull it into the body of the clipper.
Mar 18, 2010 | Andis AGC2 Hair Trimmer
Clippers are loud no matter what blade I use.
possibly make sure the blade locks into place could also be a problem with the blade drive assembly.
Sep 03, 2009 | Andis Health & Beauty
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Andis ag2 clippers sound loud
Check the tension of the hinge assembly which you slot your blades onto the hinge should be stiff (not moving by finger) also check the latch is connecting when the blades are fitted (check the blades wont pull off without depressing the latch. Its possible the blade drive may require replacing again they do not last long if your a busy groomer.
Apr 20, 2008 | Health & Beauty
Andis Dog Clippers - AGP Super 2-Speed purple Logo
151 people viewed this question
Top Andis Pets - Others Experts
Ross Keen
Anglia Clipper...
adam adms
adam adms
Are you an Andis Pets - Other Expert? Answer questions, earn points and help others
