Question about YouTube Videos
How do I change the distributor in a 1995 K1500 Chevrolet with a 5.7L engine.
1995 K-1500 w/5.7L V-8
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Put the engine on cylinder #1 manually by turning the crank pulley line up timing marks make sure the key is off and battery is disconnected. If you have a distributor cap check to see the rotor is pointing to terminal 1 on cap(it should be pointing to the front of engine toward the left side as seen from the drivers seat). take off the cap leave the wires in and lay it aside, unplug the wires from the side of distributor base and use a distributor wrench to loosen the single bolt under the large flange that the dist. cap rests on, it is in the in block there is a fork like clamp holding it down. take the bolt all the way out and remove the clamp . the distributor is now ready to come out LIGHTY tap up on it if it is stuck the shaft will turn a little as it comes off the cam gear. there is a slot in the oil pump shaft that has to line up with the end of the dist. shaft it can be tricky to line back up but if you got this far it shouldn't be much of an obstacale . Just hold the dist. and turn the shaft onto the oil pump drive shaft, if by some chance it moved to far you can put a long screwdriver in the hole and move the pump shaft Good Luck
Posted on May 02, 2013
Ok so i have 95 chevy silverado i change plugs wires,plugs,rotor button, distributor cap, fuel pump,fuel fiter and it still is missing up i have to hold it to the floor and it takes a bit to crank anyone...
Check distributor I have a 93 1500 pull cap and trun engine over watch the shaft if nothing turn truck off and check free play on rotor bug shaft
Jan 28, 2013 | 1995 Chevrolet K1500
I need to find the correct spark gap setting for a 1995 Chevrolet Cheyenne truck. It has a 1500 / 350 engine.
Make: CHEVROLET Cheyenne
Model: C1500 and K1500
Year: 1995
Engine: V8 - 5.7L - FI - - GAS
Part Number: RV15YC4 (Original Equipment Manufacturer and/or Original Equipment Equivalent)
GAP .035"
Hope helps (remember rated and comment this).
Aug 25, 2010 | 1990 Chevrolet Celebrity
My 1989 Chevrolet 1500 4x4 with a 350 stopped running. Checked the fuel pump changed the rotar cap rotar button and the coil. What else could it be?
Replace the pick up coil in the distributor,they are bad to go out.Also,while you are in there remove the ignition module and have it tested,to make sure it is good.
Jul 14, 2010 | 1995 Chevrolet K1500
1995 Chevrolet K1500 Z71 350 4x4. I have a check engine code 43 and have replaced: fuel filter, fuel pump and screen inside the tank, egr valve, plugs, wires, distributor cap+rotor, pick up coil that's...
As much money as you have spent, you could have fixed it and had a lot of beer money left. First thing to check is the KNOCK SENSOR. should be located near the starter.
Jun 04, 2010 | 1995 Chevrolet K1500
1995 chevy p/u with 4.3 engine 1500 series.
code 12 is always present in gm motor products. it simply means no tach signal because engine is not running. i would go with the simple first and clean the throttle body real good . that takes care of 99% of idle problems.
May 04, 2010 | 1999 Chevrolet K1500
What is the firing order for a 1995 chevy k1500 and what order do they go on the cap ? 1-8-4-3 ect where is number 1 on the cap and do they go counter clockwise or clock wise Thanks joe
Hello, I have attached a figure to help you out. The point with out the black dot is Number one on the distributor. Hope this helps. Please rate.
Apr 21, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Plug wire location on a 1995 gmc 1500 4x4 5.7L. i need location for wires on the distributor
not sure off hand but if you can find the wires over the sparkplugs follow there and they will go to the distributor
Jul 08, 2009 | 1995 Chevrolet K1500
YouTube Videos Logo
56 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
