Question about Andis Agp 2 Speed Professional Dog Clipper With 10
Andis clipper blade
I can slip the blades on, but it will not lock the blades in place. I can simply push the blade backwards and it will come off. I have replaced the Blade Drive and it did not help. What can I do to fix it? I need to be able to use it ASAP.
  • 193 Answers
Either the blade latch is faulty or the blade socket needs changing you are better off sending them away to have the socket changed as the setup is critical to cutting performance.
http://www.angliaclipperservices.com/Clipper_Sharpening
Posted on Nov 16, 2015
  • Andis Master
  • 1,318 Answers
The blade latch may be broken or not engaging correctly
Posted on Dec 03, 2013
Andis Clippers not locking
Make sure you are putting the blades on with the clippers running otherwise the blade will not locate correctly. Failing that it could b e a broken 'latch' AGC
May 01, 2013 | Andis Dog Clippers - AGP Super 2-Speed...
I have an Andis AGC 2 speed and I cannot figure out how to get the blade on and make it stay on when I turn on the clippers.
Ok you should be connecting the blade whilst the clipper is on this will ensure the blade engages with the clipper correctly, simply push the front edge of the blade into the clipper untill the latch has snapped into place.
Aug 19, 2011 | Andis AGC2 Hair Trimmer
I have a Andis AGC super 2, I have only owned this since last summer so this unit has only been used 9 times. I cut three dogs and I have been through 6 drivers. WHATS the DEAL!!! I am going crazy. When I...
ok firstly you must oil the blade every 15 min's or so this wil prevent rust build up and also prolong the life of the blade. (further details can be found at http://angliaclipperservices.com/clipper_blades.html)
ensure the blade is snapped into place correctly this can be done by pushing the front edge of the blade away from the clipper. The blade should not detatch without the black latch being depressed so if he blade comes away simply push it into the clipper with it running until it is in place.
Apr 26, 2011 | Andis AGC2 Hair Trimmer
CisfI bought an Andis Pet clipper AGC 2 speed. Have 2 blades - 7FC and 10FC. have lost directions on how to change the blades - can you send me directions so I can print them?
With the clipper running, grasp the blade set by the edges and flip it down away from the clipper on its hinge. Simply slide it forward off the tang and slide another blade while the clipper is running. Snap it up toward the clipper and you're set.
Apr 10, 2011 | Andis Health & Beauty
I have andis AGC 2 dog clippers. I have having trouble taking off/removing the blade that came with the clippers. The under portion of the blade assembly seems to be stuck. Also, since I'm having so...
Ok you need to locate the Latch which holds the blades into place. There should be a black piece of metal at the rear end of the clipper blade whilst on the clippers, simply push this in towards the blade and at the same time pull the front edge of the blade away from the clipper to release this should simply pull off in a forward direction.
Fitting is easier slide a blade onto the tongue of the Hinge Assembly and pull it into the body of the clipper.
Mar 18, 2010 | Andis AGC2 Hair Trimmer
How to change blades. I was abe to remove the bland, but how do you get it back on?
If you are dealing with a 76076-010 clipper, this is how you remove and replace the detactable blade. There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place. If the tongue has gotten pushed back against the body of the clipper, simply insert a screwdriver blade behind it and pop it back out so that you can slip the blade back on it.
Hope this helps you.
Oct 14, 2009 | Oster 76076-010 Hair Trimmer
Clippers are loud no matter what blade I use.
possibly make sure the blade locks into place could also be a problem with the blade drive assembly.
Sep 03, 2009 | Andis Health & Beauty
My andis agc2 clippers will not cut hair now.They are also a little noisy.The blades have been sharpened and are oiled.
Providing the clipper blades have been correctly sharpened try replacing the blade drive assembly which wears in width and can cause numerous problems.
Jul 04, 2009 | Andis 01690 Hair Trimmer
How di adjust blades to make andis clippers sharper
Take blades off clipper,loosen screws on blade, place on mirror, rest teeth against mirror, angle clipper at 1 oclock position, slowly titen screws
Jun 15, 2009 | Andis Outliner II Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Andis Agp 2 Speed Professional Dog Clipper With 10 Logo
169 people viewed this question
Top Andis Pets - Others Experts
Ross Keen
Anglia Clipper...
paul tooker
Are you an Andis Pets - Other Expert? Answer questions, earn points and help others
