Question about Vtech Cordless Phone Battery for 2429, 2498, 9110, 9119, 9152, 1712, 20-2438, 2101, 2121, 2151
Ia5849 manual lost manual..."message waiting" keeps flashing, have cleared all messages
How do I check L1 message waiting
I had the same issue on my RCA 25255re2 and worked with customer service at RCA. They had me hold down the delete button for 5 seconds, release the delete button, then press delete one more time. That cleared the phantom L1 message waiting issue we were having at my office
Oct 12, 2012 | RCA Lands Phones
Flashing red light, like I have a message waiting, however I have cleared all messages and it still flashing red. Uniden DECT 6.0
Does your phone service provide you with a voicemail box? If so, you likely have a message waiting for you on your voicemail inbox.
Aug 13, 2011 | Uniden Cordless Phone
I have a uniden dect1580 6.0 and the red light in the left hand corner blinks all the time.
That is the message waiting indicator, it is telling you that your Call Notes (Or whatever your service provider calls it's voicemail) has a message waiting. If you do not have a message waiting, you can turn the light of by following these steps:
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes and
appears in the handset display. In the event your message waiting light gets out of sync with your phone company’s
voice messaging system, you can manually reset it back to the “No messages waiting” state.
Press and hold FIND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
A beep sounds and the message alert tone is reset.
Jan 21, 2010 | Uniden Cordless Phone
Have no message but red light keeps flashing
The term we used for this back when I worked for the phone company was a "stuck message waiting indicator" and the way to fix it was:
Call yourself and leave a message.
Hang up and wait 2 minutes (we used to say 5 minutes, but 2 is plenty)
Retreive/delete your voice mail message
That should clear the blinking light.
Jul 09, 2009 | Uniden Cordless Phone
Message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
Nov 11, 2008 | Astra Meridian 9417 Corded Phone
Msg button flashing
go to the phone where the light is flashing press intercom #409. you may have to do that more than once. Keep doing it until the light goes out.
If the phone system is a DK 8 orDk16 press intercom 409 this will cancel the message waiting light that could have been cativated by a different extension.
Sep 22, 2008 | Toshiba DKT-2010 Corded Phone
Erase messages
Have you tried the telco message waiting clear?
Options, 10, *, Line Key
Try for each line key and see if that helps.
Jul 30, 2008 | Aastra Telecom Aastra Venture Corded Phone
GE model 25922 cordless phone (2 unit set) "new Voice Mail" reads out on phone, base unit charger continues to blink as a result. No way to clear it. Model does not have voice mail capability...so what is...
That blinking indicates a message in a third party voicemail (voicemail provided to you from your phone company), contact them as they may be charging you for a service you do not use.
If you need the manual here it is
http://assets.twacomm.com/assets/pdf/34197.pdf
The below is pasted from your manual
Charge/in use indicator on the base flashes
• Provided your phone company offers voice messaging service and you subscribe
to it, the charge/in use indicator on the base flashes when the phone is not in use
to indicate there is a message waiting. It stops flashing after the message has
been reviewed.
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Lands Phones
Red message light flashing
Feb 12, 2008 | Uniden Cordless Phone
Fixing message isssue
You can also press #409 on the phone to clear the message waiting indicator.
Mar 29, 2007 | Toshiba DKT3010SD Corded Phone
Lands Phones Logo
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
