Question about Vehicle Parts & Accessories
Loss of acceleration
Sorry for not speaking in the video. Received a battery/alternator error yesterday, the engine died, restarted and now won't respond to accelerator. If it was clear enough in the video, while idling the engine is revving up on its own constantly. I checked the voltage on the battery and alternator, and that seems to be ok.
  • 5,680 Answers
Check fuel filter,air filter,tune up ,wires,coils.
Posted on May 01, 2013
4 Suggested Answers
  • 36 Answers
SOURCE: I have a 2007 Volvo
It did happen to me too.Is true that i had another mark but anyway , you can look on it. Gas hose can be throttled and cannot let the fuel to accelerate the engine how it should.Good luck.
Posted on Jun 12, 2011
InMrFixIt
  • 121 Answers
SOURCE: 84 Camaro with 86 engine
Hi! supafuzzy
After recharging the battery, load test, a bad battery dirty terminal could be a problem. With the engine running what is the Voltage at the alternator and battery. It should have 13.4 to 13.8 Volts, at both locations. R&R Alternator. This should be the voltages at the fuse pannel. The HEI ignition needs good voltage for a hot spark. Other things to check if alternator and fuse panel have good voltage, Ignition Switch, Fuse Panel, Connections at Distributor.
InMrFixIt
Posted on Jun 25, 2011
  • 14585 Answers
SOURCE: Hi, I am working on
Most alternators put out around 14.7 volts. Yours is alittle high. You might check it with another meter to be sure. Voltage does drop when the engine is running and has a load on it. ie lights, A/C, Blower. radio. As long as it stays above 12 volts it is working. I have bought parts before that last only days, so I wouldn't worry about the first alternator. If the voltage drop continues (say to 8 volts?), Then I would check wires (loose connections). The first would be the ignition wire going to the starter. On your year the battery power went to the starter and most of the ignition power ran from there. There could be several wires from the starter hot side. ( sorry I can't be exact, I haven't worked on one for awhile). Also check the grounds, battery to engine, engine to body, battery to body.
Posted on Jul 15, 2011
Quits accelerating after 45-55 mph
It might be a blown head gasket!
May 16, 2013 | 2004 Pontiac Aztek
Two months ago I went through the car wash and my ebrake and battery lights started flashing intermittently heater blower losses strength when I accelerate and the headlights dim. Started idling crappy at...
it sounds like you have a bad ground. follow all your ground wires. should be one to the engine, body, and maybe frame. disconnect them and clean the surfaces with sand paper and reconnect
Jan 20, 2013 | Cars & Trucks
Keep charging battery an it dies
Sorry to say that it sounds like one of the cells in your battery has 'died'. It will show a full charge when sat on the bench but as soon as you put a heavy load (like the starter motor) on it it won't want to know. Only solution is a new battery.
Jul 07, 2012 | 2005 Chevrolet Cobalt
90' Cadillac brougham digital dash going haywire then engine dies no restart.
big draw on battery ,,, get second check on alternator ,,,, then use ammmeter to see whats taking all the power from system
Feb 14, 2012 | 1990 Cadillac Brougham
2001 Yukon SLT, engine will not turn over - friends think it's the alternator. Battery is 2 yrs old. My friend tried to jump start it, that did nothing, still won't stay turned on. I got the...
Hi there !
I won't say its an alternator problem because the alternator only charges the battery when its on, And it should start with the jump cables even if the battery and the alternator are bad. your Issue is not clear. Does the car start when you jump it ?
Aug 15, 2011 | 2001 GMC Yukon Denali
Ok I have a 89 chevy 1500, it start, runs, and go. When I hit the blinker signal, the battery volts drop, and when I come off the brakes and accelerate, the brake and battery light come on and 5 seconds...
It's either your battery or alternator have them tested. If your alternator is bad it wont charge the battery. If the battery is bad it won't hold the charge from the alternator. Good luck!
Jul 04, 2011 | 1989 Chevrolet K1500
This morning, while accelerating, the engine revved up...like I was in neutral. I restarted my06 jeep cherokee and drove home. This afternoon when started, the engine would turn over then a few seconds...
first, check (or have checked) the battery-it may have a damaged cell and is no longer putting out 12.5+ volts, which is necessary for a modern engine's ecu-a digital voltage meter (less than $15) will tell you is this is your problem.
Jun 21, 2011 | Jeep Grand Cherokee Cars & Trucks
I have a 1996 Mazda MPV where the engine fuse keep blowing. This happens after the battery was removed. Here is what happen. The alternator die one day. I replace the alternator and everything work...
There is a diode in the alternator that you fried the instant you disconnected the battery....go get a new alternator. This was an acceptable test on much older cars, but not these days......
Sep 18, 2010 | 1996 Mazda MPV
Battery or alternator
I suggest you pull the battery and alternator then take them to a auto parts store for testing. Most major chain stores will do this for free. Another alternative is to get the car running with a jump or battery swap. After you get the car running remove the positve (red) battery cable. If the engine dies the alternator is not working. If the alternator is bad you will want to get your battery checked. The alternator going out could have damaged the battery so that it will not hold a full charge. Good Luck!
Aug 01, 2009 | 1996 Chevrolet Cavalier
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
