Yamaha rx v420 phono plug in for record player
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: want to know if it
hi,
Only you can hear the record player through the aux of your amp if the record player comes with built in phono preamp. If not you need a phono preamp between the record player and amp or an amp which have a phono input. Phono preamp is available in the open market.
ok
Posted on May 22, 2011
How do I connect my Yamaha RX-V733 to cd player?
Assuming the CD player has a standard 3.5mm headphone jack, get a 3.5mm to RCA audio connector. Put the 3.5mm plug into the headphone jack at the back of your CD player (or audio out if that's what it's labeled) and attach the white end of the RCA jack to the white connector in the Phono at the back of your Yamaha RX-V33 and the red end to the red RCA connector just below it in the same Phono area.
Switch the Yamaha to "Phono" and start the CD player. You should hear things now.
Feb 21, 2017 | Yamaha Audio Players & Recorders
I need to conenct yamaha rx v420 to Samsung tv
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V420.pdf
Mar 31, 2014 | Samsung Security Cctv Sod-14c Soc-120...
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Hi I need some help with my Yamaha RX-V463. Im trying to connect my vinyl player, but not sure how to do it. can you help me?
There is no "Phono" input, you will need a "preamp" to make it work correctly. The preamp will add the grounding input loop that is missing on the receiver. depending on the quality of Phono you are looking to connect it to, will determine how much you may want to spend. They range in price from $25.00 to ........! Check Google shopping or EBAY. Hope this helps
Jul 02, 2011 | Yamaha RX-V463 Receiver
Want to know if it is possible to hear a record player through the AUX plug out? since my Yamaha RX-V396 receiver doesn't have a phono plug out
hi,
ok
May 22, 2011 | Yamaha RX-V396 Receiver
Can an ipod or mp3 player be hooked to a Yamaha RX-V596, using an auxliary cord
Typically you can find an adapter / cord that contains a 3.5mm headphone plug on one end and a pair of RCA plugs on the other. These RCA plugs should be able to be plugged into any available input on a receiver that isn't a PHONO input. These cables can typically be found online at various different places. Not to promote one site over another, but I have had good luck finding random cables like these at Cableswholesale.com and allelectronics.com. Hope this solves your problem.
Thanks,
Ben
Mar 29, 2010 | Yamaha RX-V596 Receiver
How much for a digital board for my yamaha a/v rxv 420 ?.an expert check my a/v and tell me the problem is the digital board.
What concerns me is why do you need a digital board, which cost around $150 or so. I just repaired a rx-v620 that needed the volume and mode crols replaced. These controls affected mant aspects of the digital circuits opperation. Your 420 could have a similar fate. What is it doing?
Jul 17, 2009 | Yamaha RX-V420 Receiver
Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
May 12, 2008 | Yamaha RX-V420 Receiver
Yamaha Natural Sound Amp and Tape Player
All of this applies to nearly any analog consumer audio gear...
If you have any Tape Deck and an Equalizer and only the one Tape Monitor loop you should place the EQ into that Tape Monitor loop, then place the Tape Deck onto one of the probable two Tape Monitors on the EQ as it sounds like you had here...
"When I had it set up with the graphic equaliser,pressing tape monitor on the amp and on the equaliser gave me play backfrom the tape player."
That setup will allow you to apply EQ to any analog source and the tape deck in record or playback mode.
However, if you want to remove the EQ and use the Tape Deck directly on the Tape Monitor just attach the deck's Playback cables to Tape Mon In (Play) and the deck's Record cables to the Tape Mon Out (Rec). Flip the Tape Mon control to hear the tape deck or monitor it while recording.
NEVER plug anything but a turntable into the Phono. It has a preamp that expects a ver ysmall signal from the cartridge AND it also has a severe RIAA Equalization curve which would result in grossly exaggerated frequency extremes if you managedto get a non-LP source into it. Likewise, turntables without internal electronics mut always use the Phono section of a receiver, preamp or integrated amp to get the boost and EQ they need.
Mar 23, 2008 | Yamaha RX-Z1 Receiver
Yamaha RX-V420 Will Not Power up
Hi Daniel if your set does not have a fan that trips on when the volume gets louder surely the audio output will damage. every working component generates heat and when the heat sore up to an uncontrolable level it cause damage.have a tech look on your set to repair it.good luck.
Apr 26, 2007 | Yamaha RX-V420 Receiver
29 people viewed this question
 Grubhead
Grubhead
