Question about Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill
How do you remove the armiture from a bosch 199vsr drill
How to remove coil from housing
3 Suggested Answers
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
comax
  • 154 Answers
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Posted on Apr 13, 2009
How to remove selector knob from bosch hammer drill gbh 2-20 s
Take a little screwdriver under the knop and jump him out BUT be carefull there is a little metal pin inside the knob that can be loose and easy lost .
And important Jump out the knop (BEFORE) you have removed the 4 screws of the black house.
Jan 09, 2016 | Bosch Drills
Bosch4100saw motor trouble
Hi. It could be a weak field. Or the rear bearing (or front one) on the armature is seizing or gone. If you remove the back part of the motor housing you can see the rear portion of the armature - look for a black burnt area around the perimeter. Regards.
Sep 09, 2013 | Bosch 4100 09 10" Worksite Table Saw...
How to remove necessary parts from Bosch PSR 12 cordless drill to recharge the battery?
You shouldn't have to remove any parts, except the battery itself, to charge the PSR12. I did find a breakdown of your drill that shows a 'Battery Retaining Clip' that is a heavy, u-shaped wire that goes into the front of the housing section just above the battery. It may have to be removed to get the battery out.
Nov 25, 2012 | Bosch 12 Volt Cordless Drill
How do you change the brushes on a bosch 36 v-li
Once you have removed the 4 screws holding the gearbox to the main body take off the right hand half of the housing leaving the left half on the work bench. Unscrew the 2 screws that hold the brush holders down and remove the old brushes and refit with new ones. Rebuild in reverse.
Oct 24, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
My makita cordless drill barely turns and is smoking
If it's pulling hard then gets hot enough to smoke your problem could be in either the motor or transmission. If you can, seperate the motor from the trans and try running the motor by itself. If it spins free and strong, you have a jammed transmission causing the motor to over heat. If it still labors your problem could be with the armature bearing(s), brushes, or armature windings.
Aug 19, 2012 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Hilti TE14. It rotates slowly and i'm getting a burning smell from the area around the armiture?
I would bet the armature is shot for sure and possibly the field. When an armature shorts out it usually gives off excessive sparking from the brush area. When a field fails it will usually run very slow if at all.
May 17, 2012 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Replacing cord on Bosch Hammer Drill
I don't know what model you have but most Bosch hammer drills have three or four screws on the backside of the handle that, when removed, let you split the handle from the motor housing and gain access to the switch and brushes. The screws may or may not be covered by a rubber, non-slip covering that you'll have to peel back to get at them.
Jan 28, 2012 | Bosch Drills
I was drilling and it started smelling kinda like burnt plastic. now when i pull trigger, nothing happens at all. the drill is a bosch 1194vsr hammer drill
Sounds like you need bushings do not try again till you replace then as you may damage the armiture......
there should be two plastic slotted screw caps somewhere on the drill........remove those and a bushing will pop out replace those by ordering fron tool repair shop......should cost only a few dollars
Feb 14, 2011 | Garden
My 1199vsr hammerdrill from Bosch will not start. A couple months ago, I lost variable speed (ran at full rpm or nothing). Noticed a lot of comments on line about this model not starting. Wondering if...
It could possibly be that your brushes (Bosch part number 1617000525) are worn down to where the drill won't work any more. Take the two screws out of the back of the handle and remove the housing cover to check them. More likely your switch (Bosch part number 2607200918) has gone bad. If you lost the variable speed a while ago that was a sign the switch was already breaking down. Also located inside the housing cover, you can check for burnt wires or melted plastic around the switch but it is possible the switch is bad without having any visible problems outside. Fairly easy to replace, just make sure you connect the four wires to their proper contacts.
Feb 09, 2011 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Bosch 11247 Hammer drill works in drill mode but in hammer mode it spins as drill but does not hammer. Also how can I remove drive shaft from housing?
Feb 27, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill Logo
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
