Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
Not starting model num 911311 ser num 000196. aries lawn mower, my problem is it wont start only on prime, it has a float but theres no choke, the pipe from the carb to the valve that carries the fuel was replaced as it was broken, it seems there is no suction to draw up the fuel apart from priming, carb was cleaned numerious times and fuel tank too, any help is appreciated tanks.
4 Suggested Answers
  • 23 Answers
SOURCE: how do I know if
Check air filter. Try to run without filter. If not, add gas through carb and see if she'll fire. If she does,
clean the jet
Posted on Dec 18, 2010
  • 14 Answers
SOURCE: Mower starts and immediately shuts off and wont
Pull the fuel line from the carb & see if it is running steady, If so the next check is the carb bowl to see if maybe the float needle is partly plugged, and then it could be the valve lash clearance which will require more mechanical knowledge.
Posted on Jul 15, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I have a Kohler courage
Hi
Sounds like you have dirt/debris in your caburetor inlet fuel needle valve, this will cause the float needle valve to stick open and allow fuel to run out of the carburetor unchecked untill you empty the fuel tank.
Sometimes you can tap on the carburetor lightly with a hammer and dislodge the dirt/debris from the needle valve.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
Make sure you are using fresh fuel.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Posted on Aug 23, 2011
Push mower wont start via key or pull
Try having it tuned up and the spark plug replaced.
Aug 24, 2014 | Garden
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
My 190cc, no primw, no choke engine stalls after a
Clean the carb bowl out. Check for water in fuel. While the carb is open check the float for obstructions and good volume of flow.
Make sure the float height is within spec. You will need to go the BS website and get this spec with your motors model and serial number. Normally floats are good when they sit level at the point the fuel stops flowing.
Good luck and be careful!
Jul 22, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
I have a Sears craftsman lawn mower that will not stay running. The model # in the engine is 12h887-2314-E1. Can you give any suggestion?
Your engine parts list can be found here: http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=12h887-2314-E1
There are 3 different carb variations on this unit.
Primer type
Choke type
Auto-choke type?
On the Primer type with the plunger on the side of the carb the primer bulb gets a pin hole in it that allows air to be drawn through the primer bulb. So the engine will start an then die after priming.
On the Choke type carb debris in the bottom of the float bowl AND bowl nut will cause this.
On the Auto Choke type there is a diaphram under the carb that can get damaged and allow airflow where there should be fuel flow.
I am pretty sure that your mower has the float bowl on it. remove the bowl nut... take some carb cleaner and spray directly up into the hole the bowl nut screws into and clean it. Then also spray around the float needle.
If your still having problems.. just fro grins remove the fuel supply line to the carb and check for fuel flow. If there is little or no flow either the fuel slector is off or the fuel tank outlet has debris covering the tank outlet hole inside the gas tank.
Thanks for using FixYa.
Kelly
Jul 04, 2010 | Garden
Starts but wont keep running
The fuel bowl has a float and needle, the bowl is filled with gas and over time the float gets filled with gas or just don't float as it should within the bowl. the needle is pulled up by the float which lets fuel flow into the carb. A repair kit can be bought for $5 and is easily replaced. After you take this apart, it's a good idea to clean the carb with a carb cleaner. You'll have to take off quiet a bit which looks difficult but it's really not.
May 03, 2010 | Poulan Pro " Pro" Self Propelled Mower
Our troy bilt self propelled lawn mower is about 8 years old and has served well. However it has developed the following problem: requires extra priming to start and then dies....will not remain started....
The float and needle need replacing. Take the carb off soak in a high octane gas or booster for 15 min. The float isn't floating in the gas bowl, which rises the needle to let more fuel in. When you prime the carb, you are directly shooting gas to the carb, this is why it will start and then shut down because the float can't keep gas flowing in. A kit cost about $5-7 and easy to replace.
Apr 19, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower wont start
I have the same mower and I have the choke assembly complete, I will take a picture for you if you want to show you what should be there? Mine wont start at the moment wondering wether its the magneto
stu
Jun 27, 2009 | Garden
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
