How to remove a baffle from a heatcharm c500 woodheaterRemove Baffles
The heater is just putting smoke into the house do I have to remove the baffle to clean out the chimmey
SOURCE: Need an owners manual for heatcharm wood heater
I using a heat charmIV for the first time (just bought a house and it was already installed). Am baffled over fan knob- when to use/ switch off, and the 'high/Low' options?
At what stage do I use these 2 and for how long?
Michael
Posted on Sep 09, 2011
aborcass
  • 2651 Answers
SOURCE: How to replace whirlpool duet GHW9200LW baffles
easy repair, they simply slide over hte slits in the tib and firmly pull forard to snap/lock into place. there should also be a screw included in the kit, remove the top of washer (3 screws across the back of the lid)after removing hte main top toull see a black accordian like hose leading to the top of the tub assy, from the dispensor box to the left. remove this hose from the tub( pulls out of the hole), then simply turn the tub form the inside till the baffle you installed is at the 12 o'clock positon your screw hole will be right there. RESECURE THE HOSE, reassemble the top and your done!
Posted on Nov 26, 2008
aborcass
  • 2651 Answers
SOURCE: Baffles in washer
the new baffles arefairly easy to install, they go over the hole and then pull foward to lock into place.. the new bsaffle should also come with a screw to "lock" it, in place. in order to securethis screw you need to remove the top cover of the unit,(3 screws across theback) after removing the top youll see a black hose going directly into thetop of the tub prbably an inch or so . gently pull that hose out from thetub. It simply locks itself inplace.. after removing you can spin the inner drum around till thenew baffle is directly under the "hole" where you can now see a small hole inth eunderside of baffle to secure.. just remember to resecure that hose or youll have a flood on your hands
Posted on Mar 04, 2009
SOURCE: Fix Loose Baffles
I had the same problem, one of the baffles had lost a screw and the other side was very loose. Using the instructions here, I took out the four screws inside the door. Two hold the hinges of the door on and two are on the opposite side and hold two small plastic parts on. Once these are removed, pop the front panel off from the top, it hinges down and lifts off. You can now see under the drum and rotate the drum around to tighten the screws that hold on the baffles. Replace the front panel, screw in the four screws and you're done! Thanks to this website and other responses, I was able to fix it myself without an expensive repair call!!
Posted on Jun 01, 2009
  • 87 Answers
SOURCE: removing baffles in my1300 vtx c honda ?
it is not hard to do but it would be best to get the drag pipes. there are a host of problems to think of though. you will need to rejet the carbs to accomodate the free up in back pressure. you will need the tourque slipins for the pipes. they will fit right into the pipes where they connect at the heads. the 1300 is going to be super loud without the baffels. like getting stopped by the law loud. it would be best to get a tuned drag setup from a dealer as to get the sound you are looking for as well as keep it below jonnie laws radar.
Posted on Aug 04, 2009
Napoleon NZ26 woodburning fireplace smoking back.
Get someone to come and do this correctly. You have a possible carbon monoxide poisoning hazard!!
Nov 18, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Valkyrie baffles missing
I found an article and a video for your source on how to replace motorcycle baffles. By following the instructions in the article I am sure that you can now replace the baffles on your motorcycle.
-Phanter
Continental Motorcycle Tires
Mar 25, 2013 | 2000 Honda Valkyrie Interstate
Baffles broke in front loading washer
You will need the screws to hold them in and unfortunatly to do them you have to split the 2 drums apart unless you can see where the screws mount on the new baffles, but usually they screw in from the outer side of the inner drum. A lot of work for such a small part.
Dec 29, 2012 | Kenmore Washing Machines
There is something in the drum housing between the drum and the house that is jamming the drum. how do i get into the drum housing to remove it?
You can remove one of the baffles inside the spin basket; that gives you a pretty good size opening. There is one screw that holds the baffle in place; when you remove that screw you should be able to slide the baffle and it will come out. Sometimes though, at the factory they might, or might not have, pushed a little tap that will make it difficult to slide the baffle. There is place for a second screw; make sure they did not install that second screw. I guess it all depends on which day your spin basket was put together whether or not they pushed the tab, or put the second screw. Good luck!
Jun 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Michael
May 24, 2010 | Heating & Cooling
Remove baffles from mufflers on a 1998 Suzuki VS 800 Intruder
there will probably be a couple or rivets close to the end of the muffler. drill out or chop off with a chisel. pull out baffles. but beware it will be loud. i did this to my dragstar/v star and ended up putting them back. you could just remove some of the fiberglass packing from the baffles, the cops will give you sh*t if you run straight thru. aftermarket pipes would be the real way to go, you may need to re-jet the carbs though. my bike also lost power with no baffles as engines need back pressure and all pipes are designed to give this.
hope this helps
Apr 01, 2009 | Suzuki VS 800 Intruder Motorcycles
PUTTING THE WINDOW SIZER THING ON THE AIR CONDITIONERS
That is a good question...what to call them...perhaps adjustable baffles? Anyway...have you removed the air conditioner from its housing? Most window air conditioners can be removed from the housing through the front opening. With the air conditioner removed...it may be possible to apply the screws from the inside of the air conditioner housing to attach the baffles to the outside. I may be able to give better advice if you can tell me the manufacturer and model number of the air conditioner.
Good luck... and I hope this is helpful!!
Feb 01, 2008 | Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
