Question about Sewing Machines
I NEED AN INSTRUCTION MANUAL FOR SINGER OVERLOCKER MODEL PROFESSIONAL 14U13A ALSO WHAT SIZE NEEDLES WOULD I NEED FOR IT
  • 3 Answers
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Posted on Jan 13, 2009
  • 47 Answers
SOURCE: Singer 2818 instruction manual in English
Just visit us at www.ifixmachines.com to avail an english manual
Posted on Jul 24, 2009
RickE1
  • 202 Answers
SOURCE: Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
Posted on Aug 03, 2009
  • 351 Answers
SOURCE: i need a singer advance model 7422 instruction
You can find free manuals to down load from singer ..
http://www.singerco.com/accessories/manuals.html
Please vote !!
Posted on May 14, 2010
  • 351 Answers
SOURCE: singer overlocker model 14u34b user manual
Please vote !!
Replacing needle on Singer overlocker.
The manual should have instructions. Most overlocker needles have a screw that holds each needle in place. Just loosen the screw with the screwdriver that came with your machine, slide the old needle out (note which direction the flat side of the needle is facing), insert the new needle as far up as it will go, and tighten the screw. Don't lose those screws or drop them inside the machine. If you remove a needle so you can serge without it, be sure to tighten that screw so it doesn't fall out.
Mar 02, 2017 | Singer Sewing Machines
How to change needle on Singer overlocker.
Hello Elizabeth Neilson
'not sure which Singer overlocker needs needle change. However a free downloadable manual is available here: http://www.singerco.com/support/instruction-manuals
Please let me know how this works out for you.
Happy overlocking!
Sewingirl/
What size needle does the singer merrit 8734 use
here is a free downloadable manual from singer,here's the link
http://www.singerco.com/uploads/download/672_8734-8834.pdf
in the manual in the accessories it tells about the needles,
on page 7, I believe,, general sewing singer size 2020,,
& knits, stretch, elastic size 2045
plastic bobbins
Aug 30, 2012 | Singer Merritt 8734
Singer overlocker manual 14u234/can i have it downloaded?
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 14u234) & click search
the last one at the bottom is free
May 26, 2012 | Singer Sewing Machines
What size needle to use
Use Organ HA x 1SP needles size 90 (14) for general sewing or 75 (11) for light weight fabrics. These are common needles and Amazon carries them. There are other sources. When you choose the needle size, look at your thread relative to the groove in the needle. (The thread should fit in that groove.) I use the Singer Sewing Book for good pictures of the needle to thread size.
Singer has the manuals for the Superlock 2000 ATS on their site. Part 1 of the manual is here: http://www.singerco.com/uploads/download/984_sl-2000-ats-wb-a-x.pdf . All manuals are here: http://www.singerco.com/accessories/instruction-manuals . Enter the model number without the letters after the number.
I hope this helps.
Oct 25, 2011 | White Sewing Superlock 2000 ATS Mechanical...
My manual got lost, need to remove needles, I bought a Empisal Model S4D Overlocker but the manual or CD got lost and I need to get one
look on you tube for overlocker parts instruction.generally the needle is removed by loosenening a little screw which is pushing on the needle from the from.
sewingmanual.com has manuals for sale
Sep 14, 2010 | Yamata FY812 Mechanical Sewing Machine
What type of Overlocker needles does the Elna Dex704 use? Is there a code or size I need to quote on an order?
90x14 professional needles, we have them $5.00 pk $2.00 shipping....thats our special now
Dec 04, 2009 | Elna 1010
Friends broke needle on my euro pro multi stitch sewing machine.
According to Euro-Pro.com
Where can I buy new needles?
Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
has all the information including a downloadable manual (pdf file)
Jan 24, 2009 | Euro-Pro 9120 Computerized Sewing Machine
Singer Futura CE100 Embroidery
check to be sure machine is being threaded correctly first, then when pressure foot is lowered pull thread and see if you are getting tension, if not assembly is bad
Jan 21, 2008 | Singer 7422
Sewing Machines Logo
60 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
