Question about Toshiba Tablet. Excite 10.1 in. Android 3.2 Honeycomb 1GB Tablet
Toshiba at300 problems
Will not connect to our network. claims "authentication problem".
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
Why won't my tablet connect to the internet?
Authentication errors happen when the tablet does not have the correct credentials to log onto the network. Be sure you have the correct SSID and password to join your local network. You can check this in Settings.
Apr 14, 2015 | Tablets & eReaders
Will not let me connect to wi-fi it is not my wi-fi servce. it just keeps saying authentication problem
It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
Apr 13, 2015 | Nextbook Premium 8 Se Android
Turning onto internet I get a white box up with retry o I have Got all the wifi settings up on the screen and underneath my TalkTalk_wifi number there is a sentence saying AUTHENTICATION PROBLEM ?
If your Kindle is not blacklisted, and the dialog box states that you have an authentication problem, then your Kindle is not connecting to your local network. Sometimes this can be caused by chip failure on the Kindle mobo, but usually it is due to an external network problem. You should try again once or twice and then if you continue to experience the problem, try to reset your local router by turning it off and on.
Feb 28, 2015 | Amazon Kindle Fire HD
How to unfreeze a toshiba at300 ?
Hold the power button down. Being that it is frozen may take a little longer than usual, but less than 30 seconds.
Sep 16, 2014 | Toshiba AT300SE-101 10.1" 16 GB Wi-Fi...
Irola dx752
If I am understanding the problem, then you are trying to connect to a network that is password protected (that is what the lock symbol generally means when shown beside a network that has been discovered by your device). It cannot 'authenticate' you until you key in the correct password. However, if that is the case, when you click/touch that network and then touch Connect, it should automatically pop up a box asking for the password. Key in the password (be sure to get upper/lower case correct on any letters), and then touch Connect. If that does not work, or if I misunderstood, then provide additional info and we can try again. Good luck!
Jul 16, 2014 | Tablets & eReaders
Meep will not connet to wifi
Here is the remedy for that error:
We've heard a few reports of Wifi connectivity issues recently, among them 'Authentication error'. If you receive this message, our recommended remedy is to remove all Wifi connection information from your Meep, turn off your Meep, reboot your router, then turn on your Meep and re-add the Wifi information. Follow these steps exactly in this order to resolve this error message:
1. Remove all Wifi network information from the Meep's settings
2. Reboot your router
3. Re-add the Wifi network information to the Meep's settings
4. Reboot the Meep.
Jan 01, 2014 | Oregon Scientific MEEP Kids Tablet
Authentication problem when trying to connect to the internet
If it use to work on your network and you haven't changed any router settings. You can try and "forget" your connection. Go into settings > wireless and your network should be listed. Touch and hold on your network and you should get a button "Forget Network", tap that and try to reconnect to your network.
Dec 29, 2013 | Polaroid S7 7-in. Internet Tablet
How to open a Toshiba AT300 to replace the USB connector
you could look at a step by step video on the internet or youtube. it helped me.
Nov 30, 2013 | Tablets & eReaders
No internet connection
Re-check your network connections, then tick allow other computers to connect using the same network...it will work
Jan 13, 2008 | Tablets & eReaders
Toshiba Tablet. Excite 10.1 in. Android 3.2 Honeycomb 1GB Tablet Logo
29 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
