Question about Hitachi Televison & Video
Service not running
Tv loses the sound when I change stations. Error message Service not running
    Top Expert:
  • Hitachi Master
  • 75,452 Answers
Do a reset to this TV and check.
Posted on May 02, 2013
Testimonial: "I have done a first time installation and still have the same fault. This fault is random (can take upto 7hours to occur)and only happens when I change channels.I can then put the set in stanby wait about a minute and switch back on. Tv will work normally with sound but will eventually come up with the same fault. "
  • stuart warren May 04, 2013
    I have done a first time installation on the tv but faolt sound fault is still there.
2 Suggested Answers
  • 19 Answers
SOURCE: i just lost all my digital channels. The problem
this is what i can tell you your tv has 2 boards a main one and a power supply one anything that has to do with your imputs tv, av, hdmi, etc has to do the main that includes the picture going off and sound you can contact the manufacturer and tv technicians, but the only place that its going to be cheap its at www.shopjimmy.com guaranteed
Posted on Apr 13, 2010
My HP printer shows error code 21.1.03, what does it mean?
This error indicates problem with the service station which is on the right end of the plotter. Open the window and have a look, the most common cause I run into is a piece of torn paper preventing the head from parking properly.
Apr 11, 2015 | HP Designjet T1100ps Printer
What is the solution to a printer when a message like 21.1:03 appears on the screen?
That is a service station shutdown failure.
Replace the Service Station, if that doesn't solve the problem, replace the PrintMech PCA.
Mar 05, 2014 | HP Designjet T1100ps Printer
Losing power
Try to take it to a service station for complete service
Jan 10, 2014 | 1990 Ford F350
I have a HP Z6100, and I got many times error 86:01 possible paperjam, after changing encoder strip and encoder sensor, carriage PCB. I still have 86:01 error, after Scan Axis in maintenance mode, the...
Observe when 86:10 error appearing? after intializing the carriage or immediately after powering on?
# If immediately error appearing do the below discussed activity
# after intializing if error appearing check trailing cable,service station wipers & cappings,cutter position, cutter movement & lubrication on rail.
Detatch power cable & data cable,remove right door, pull out carriage assembly from service station area (if its locked by service station manually unlock it). Remove cable connections, screws & take out service station from the printer.Place the service station out side(ensure that cables has to fix properly) connect the cables,switch on the machine, check for the error..
if error is not appearing: check the service station, found any damage replace it or shoot the problem.fix it back..
*even error is appearing: Remove carriage belt from the pully..check carriage movement, if found any hardness/obstruction? shoot the problem.
Finaly: check trailing cable( while carraige movement some tracks may lose their continuty)
Power supply.. ( check voltages)
Need your feedback for further help.. vinay229229@yahoo.co.in
Apr 11, 2012 | HP Designjet Z6100ps InkJet Printer
Error code 21:13 restart the printer if the problem persists,call hp support
It all depends on the machine but typically all the 21 errors relate to the service station. this is the part to the right of the machine that "caps" the carriage and print heads when the carriage parks after a print. 13 refers to power cycling the machine to reboot it. If you need more precise info you will need to post the model and more info.
Aug 25, 2011 | HP Designjet T1100ps Printer
HP Designjet 500 24-in Roll Printer error message 2110
Service Station failure. The possible cause could be:
The steps counted by the Service Station motor are not consistent with the expected length of the current movement.
The Aerosol Fan has reached its maximum current limit.
The Service Station motor has shutdown because of blockage.
8x8.gif Corrective Action 8x8.gif 8x8.gif Try the following:
Remove ALL the Printheads and clean the flex contacts on the Printheads and in the Carriage Assembly.
Replace ALL the Printheads.
Replace the Service Station/Aerosol Fan Assembly
Apr 05, 2010 | HP DesignJet 500 InkJet Printer
I have Hp Plotter 500 and i am getting error code 21:10.
your printer error message 21:10 is about service station or carriage problem, the fix steps follow here:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html#P16_845
hope help you fix it. take a rating let me know how much helped you thanks!
May 21, 2009 | HP DesignJet 500ps InkJet Printer
21:10 error
Hi HotRoddy,
This is a Service station error. Check for obstructions in the service station on the right.
Turn on the printer in service mode by holding down the UP arrow and ENTER keys (simultaniously).
Enter Service Utilities, choose Unlock Carriage. Turn the printer off and move the carriage to
the center of the printer. Turn the printer back on. The carriage and service station should
return to their home positions.
If the error returns on power-on, the service station will probably need to be replaced.
Parts and diagrams can be found at partsurfer.hp.com.
Hope this post was usefull for you.
Thanks,
Robosoft.
Jan 04, 2008 | HP DeskJet 500c InkJet Printer
Televison & Video Logo
109 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
