Question about Garden
When you pull down the handel for the blade to start nothing happens
  • Garden Master
  • 2,478 Answers
Check your deck belt, may be off
Posted on May 02, 2013
How fo i fix blade height adjustment on dewalt dw744x , for it has to much ply/slop on it. Yes its spotless, and lubed up
http://www.ereplacementparts.com/dewalt-dw744x-type-table-saw-parts-c-1009_2657_3818.html
Beawared there are much parts obsolete and maybe not available anymore , look before selling the total condition of the table before selling .
Mar 16, 2016 | Saws
Key won't start my mower
starer is dirty take apart and clean dirt out of it reassemble star it
Sep 08, 2014 | Toro Recycler 22" 149cc Personal Pace Lawn...
Blade control will not engage. Engine will not start.
Well, If it worked last time...I would say it is the gas..moisture..
if not, then both ends of your cable. If nothing moves. it is either broke or came undone from lever by engine. I lean toward the gas, especially if it sat up all winter. (A new plug would be a good idea,Stranger things have happened) I had to do that to mine.
Mar 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
I set the temp on the fryer and nothing happens. how do i know it has heated up
U need to set a time on the timer according to the booklet
also u need to put the handel down for the light to come on and the unit to run/ turn on.
I hope this helps......
Feb 11, 2013 | Chef's Mark 16cup Professional Fryer
Blue light stays on
Lift handel and pull wall plug. Replace plug and insert Kcup and pull handel down firmly. It is rest now.
Feb 01, 2013 | Keurig Elite B40 Coffee Maker
The brand new blade rolls off the pulleys, thus not cutting. help!
You need to pull the bar out to tighten up the chain. The chain will stretch a lot the first day, And it will come right off. Check out the adj screw on there and loosen up the lock bolt/s, tighten up the bar, tighten up the lock bolts, Make sure the chain moves, not so tight it gets hot and freezes up. You should be all set. If the chain is stretched beyond the adj, you will need a new chain or get a link taken out of the old one, the hardware store, saw shop can do this for you.
Nov 28, 2010 | Garden
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
2000 astro I set the parking brake but when I pull the handel to release it nothing happens. the lower panel was droped down and I think something came lose at that time. I don't have anything to go by...
Oh Oh try to release cable at control if cable is loose its siezed cables at drum get vise gripes to push pack toward drums & to pull drums to fully release
Aug 30, 2009 | 2000 Chevrolet Astro
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
