Question about Kenmore 63942 Dryer
Rattle noise rattles in the back when drying and gets very hot
  • Kenmore Master
  • 8,220 Answers
You have an obstruction inside the dryer chute the fan is rubbing against it I have seen this before. Here is my Roper whirlpool inglis maytag dryer cleanup
Posted on May 02, 2013
  • 3 Answers
SOURCE: Kenmore Dryer
Your thermostat could have problem and it confused the temporature inside the dryer. You should change the thermostat. To make sure you can use VOM (vol-amp-milimeter) device to check it. If it reads 0, it means OK. If it reads another number, it is faulty and need changing a new one.
Good Luck
Posted on Aug 18, 2008
  • 409 Answers
SOURCE: noisy dryer
hi there,
the rattling and squeeling noise usually comes from the drum shocks. they do wear out due to use. i would recomend replacing them.
Posted on Oct 11, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Posted on Dec 29, 2008
  • 351 Answers
SOURCE: top loose, new dryer not level? rattle when start
No dryers are not self leveled. You may not have put the legs on ? they come in the box or if you have then you need to prop them up with a 1x4 or something.
Posted on Apr 19, 2009
  • 512 Answers
SOURCE: loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Posted on Aug 17, 2009
Irritating rattling noise is coming from the motorcycle's engine when hot, no rattling when cold.Too much vibrations when hot. Motorcycle: HONDA CB UNICORN 2013.
Hi, Captain I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fronk Forks---Plunk
9. Gears---WHINE
10. Head Gasket---HISS
11. Hydraulic Lifters---TAP
12. Pistons---SLAP
13. Rear Shocks---SQUEAK
14. Shifting Trans---CLUNK
15. Solid Lifters---TICK
16. Starters---CLICK
17. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda CB Unicorn 150 engine sound
Top 6 Strange Motorcycle Noises What They May Mean
HONDA UNICORN CBF 150 BIKE WORKSHOP SERVICE REPAIR MANUAL Download Manuals... $14
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Jun 12, 2017 | Honda Motorcycles
Dryer makes loud rattling noise while drying
How old is your dryer? My dryer was making a horrible rattling noise and it turned out to be the idler pulley.
Sep 19, 2016 | Kenmore Elite HE4 Electric Dryer
350z clutch rattling
The vast majority of these clutch area noises come from the throw out bearing that presses on the pressure plate - the grease gets dry and starts to rattle when the bearing wears and gets loose. Other problems are loose clutch bolts or a partially broken clutch disk.
Jun 26, 2014 | 2005 Nissan 350Z
Hyundai sonata power steering
It could be a leaking hose, and the PS fluid is dropping on the hot exhaust. Check the fluid level in the power steering reservoir. If low or dry, look for a leak.
I don't know about the rattling-better have someone look at it.
Feb 09, 2014 | Cars & Trucks
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
My dryer has started to make a loud rattling noise when drying. It works fine but the rattling noise is coming from the lower back part of the unit and nothing seems to be loose. What can I do?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 18, 2011 | Maytag Dryers
VW golf 1.4s 2004 / rattleing noice when hot/cold air turned on.
probb. dryed out leaves or needles in fanmotor right front under the dash take out fanmotor and clean fanblade.
Feb 10, 2010 | 2004 Volkswagen Golf
Kenmore 63942 Dryer Logo
102 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
