Question about Dometic RM2652 Refrigerator
Why did 2652 stop cooling,was working and stopped.
High limit switch on boiler housing tripped,i reset it,now 12v fuse blows as soon as on switch is pushed.ihave power everywhere butj4-j10.i put 120v to heater element wires and it got cool,it is a new element,is upperboard bad or lower board?
    Top Expert:
  • Dometic Master
  • 6,394 Answers
Bad 12 volt element
Posted on Oct 11, 2017
5 Suggested Answers
ohms
  • 1879 Answers
SOURCE: Dometic rm7732 not cooling
you actually got it - check the colling unit part (connection from either AC or GAS / if it is still good or gone bad
Posted on Jun 17, 2008
  • 1796 Answers
SOURCE: Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Posted on Apr 19, 2010
GodBlessU
  • 3513 Answers
SOURCE: Dometic 2652 does not cool that well. Food spoils.
Hi
There could be leak which causes the no cooling state in your unit.To check the cooling ammonia system, the 110v heater or the 12 Volt heaters can be hotwired direct to a power source, this will check the cooling system, The 110 V is best to check. But you need a repair person to get it diagnosed.
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Posted on Aug 24, 2011
  • 3 Answers
SOURCE: Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
Posted on May 31, 2012
Kenmore Dryer fuse keeps blowing
Blower housing most likely stopped up with lint. This located behind front panel, lower section.
Sep 23, 2017 | Kenmore Dryers
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
Ac blower motor stopped working
YJ car.
the blower is dead. is that it?
does it blow full speed on high
do you have 12v on terminal A of blower , term B is 0v ground
got that, then the blower is dead.
if not 12v, then the controls are bad.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
page 47
4 parts to make blow
1: fuse 12 good.
2: switch heater /on off.
3: high, med,low speed, use high, its direct.
4: the blower,
one of those points has no 12v on high,
use a simple voltmeter to find the failed point.
Jan 14, 2014 | 1994 Jeep Cherokee
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
I have a RM 2652 fridge in my 2003 trailer and my refridgerator/freezer does not work. The check light now comes on, what could be wrong?
If your refrigerator has had a recall done on it I would check the L shaped bracket that was added as part of the recall, as it may have pinched thermal flame sensor and driving may slightly reposition it to cause an intermittent short blowing your 15 a fuse in rv panel. Remove it from the retaining fingers and slightly reposition fingers loosely around black insulation sleeve and reattach it to the previous location with the 2 sheet metal screws.
Now if the refrigerator won't come on at all check the resetable hi limit switch that is riveted to your units boiler area a few inches above your gas flame area. It has a button you can press located in between the 2 connectors.
Check for 12 VDC at the nylon terminal block in front of your main board AND on terminal J4. If power is there follow to the resetable hi limit switch on boiler. If you don't have power at all you may very well have a control board failure. You should check all 3 fuses on the control board also. So check all 4 Fuses (ONE) 15A on the RV Panel and the (THREE) fuses on the main board. If any of them are blown you can replace them ONCE only. If it blows the 15A Fuse on the RV panel again your going to have to locate the short most often from the RV panel to the main board on the refrigerator. If the fuses on the mainboard blow your going to have to troubleshoot the refrigerator wiring.
Thanks for choosing FixYa
Kelly
Sep 02, 2010 | Dometic RM2652 Refrigerator
My dryer will turn off after a about 10 minutes and then need about 2 minutes to cool down before it will start again. When I push the start button before the 2 min are over the machine will not start. Any...
Sounds like the high limit switch. It is a small round disk shaped part at the top of the heater coil box. If the temperature gets too high then it trips this, after it cools off it resets itself. So either the limit switch is going bad and tripping early and coming back on late. Or the dryer is overheating, maybe the vent stopped up with lint?
May 21, 2010 | Dryers
I have a dyno glo rmc-fa100dlx forced air heater. It will light and work for a few minutes, up to about 5, then it will stop heating and the fan will keep blowing. any ideas? thanks!
If the unit comes on and runs but then shuts down, that sounds like an indication of a high limit trip.
Most, if not all, furnaces have high limit switches that keep a constant check on the temp inside the furnace or air handler. On most systems, once this high limit switch has been made (got to hot), the limit switch breaks control voltage to the heating device (strips, gas, fuel, etc.etc..). The blower motor continues to run until the high limit has dropped in temp and reset itself.
On some models, the high limit is a manual reset, meaning you need to reset the switch yourself or shut the unit off and then back on to reset it.
Check all filters and replace as necessary. Check the coils and fan blades for dirt build-up and cleanliness. Check motor belt (if applicable). If all these fail to solve the problem, then your issue either lies within the blower motor itself not moving enough air for proper heat transfer. Or the high limit switch itself is failing.
Jan 09, 2010 | Heating & Cooling
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
Dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Aug 22, 2009 | Refrigerators
Dometic RM2652 Refrigerator Logo
94 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
