Question about Neo M74S
Need wireless properties wifi set - Neo M74S
  • NEO Master
  • 7,627 Answers
I'm not sure what it is you want? "properties wifi set"? Can you rephrase the question?
Posted on May 02, 2013
How do u unlock your wifi
if you own your own wifi router, please go to the settings and set the wireless access to Open. This is not advisable to prevent people from snooping/leeching on your wifi, probably drawing considerable bandwidth at best or causing destruction to property at worst.
Oct 20, 2014 | Linksys Wireless-G WRT54G Router
Tip
How to Connect a Laptop to a Wireless Router
  • 1 Purchase a wireless router that fits your needs and price range.
  • Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • Click on "Properties."
  • Select the "Wireless Networks" tab.
  • Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Avable Networks" section.
  • Click on "Configure" when you see your network's SSID in the "Available Networks."
  • Enter your network's SSID and WEP key.
  • Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • on Oct 08, 2010 | Computers & Internet
    Tip
    Belkin F5D7234-4 v1 (important thing)
    In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
    • If you do so, then the router will no longer work in 90% of cases.
    • The WiFi protected setup is enabled by default in this model.
    • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
    Solution:
    In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
    WINDOWS XP:
    Start>
    Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
    WINDOWS VISTA:
    Start>
    Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
    WINDOWS 7:
    Start >
    Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
    • Now try to access wireless network.
    • If it still says windows cannot connect then no other go.
    • You need to disable WiFi protected setup.This will fix the issue for sure...
    Click here to know how to disable wifi protected setup...
    To learn more about WiFi protected setup, please click here...
    on Apr 19, 2010 | Computers & Internet
    Unable to download WIFI and haaaaaaaaaavnt had this computer fro long
    connection to wifi
    Turn on your computer and locate the Wi-Fi icon.
    This could be located on the upper row on a laptop it will have the radiation look (((·)))
    Make sure its pressed on.
    Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you.
    If not you may need to turn on the wifi on those devices.
    Usually those setting can be found in menus like Network Settings.
    Once it recognizes the network you will need the password if it is required.
    Just enter that in and you are set.
    Where you enter the password is usually in the same menu in which you turned on your wifi enabled device.
    if still no connection
    Power on the laptop computer and wait for the operating system to boot.
    Right-click the wireless Internet icon in the lower right corner of the desktop.
    This brings up a new pull-down menu.
    Select "View Available Wireless Networks."
    This brings up a selection of different possible Internet connections that are in range of the computer.
    Select the wireless Internet connection you want to use.
    If a password is required, you need to type it in now.
    Wait for the laptop to connect to the Internet.
    In a moment the computer is going to state it has successfully connected to the Internet.
    Click Start, Run type in cmd and click Ok to bring up a command prompt.
    Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100.
    Check your wireless connection properties under My Network Places.
    Right click the wireless connection icon and choose properties.
    From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked.
    Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
    press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
    look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
    if still no joy
    Let's first try to start the wireless service i.e. WLAN AutoConfig service manually.
    To do this, login to the computer as an administrator.
    1. Click Start, type services.msc and hit enter.
    2. Locate WLAN AutoConfig service, double click on it to open its properties window.
    3. Under General tab, change the Startup type to Automatic and click Start button.
    4. Click Apply and then ok.
    For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
    Aug 03, 2013 | Computers & Internet
    My laptop won't connect to wifi
    Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
    4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
    Feb 26, 2013 | Computers & Internet
    Cannot get wifi connection on my netbook
    Feb 19, 2013 | Craig Computers & Internet
    It is not clear if what was required is a WIFI or if you need a WIFI. To activate the WIFI all what is needed is to activate the network settings, if password is used it has to be set within.
    make sure that the WIFI drivers are installed within the PC, if not check with your dealer or support centerto download ,run and install.
    Oct 20, 2011 | Gateway M305CRV Notebook
    How to install my router for wireless internet on my laptop.
    1. Purchase a wireless router that fits your needs and price range.
    2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
    4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
    5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
    6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
    7. Click on "Properties."
    8. Select the "Wireless Networks" tab.
    9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    10. Click on "Configure" when you see your network's SSID in the "Available Networks."
    11. Enter your network's SSID and WEP key.
    12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
    Thanks.
    Have great day.
    Oct 01, 2010 | Computers & Internet
    I dont know how to connect it to my laptop wireless
    Aug 01, 2010 | Computers & Internet
    Internet access with wireless
    Assuming that your laptop has a built-in WiFi Networking card (or even a USB or PCMCIA WiFi adapter), normally its a matter of setting your Network configuration to "Auto obtain IP address automatically". This could be done in your Control Panel/Networking Connections, right click on your wireless Networking, click on Properties, highlight Internet protocol (TCP/IP), click on the Properties button and tick "Obtain...".
    In some instances you might need to key in the WEP or WPA security key if it has been enabled and set in your WiFi router, though it has been known to slow down connections. If on the otherhand the router has its MAC filter enabled, then you would need to add your laptop's WiFi MAC numbers to the list that the router would allow access to.
    Should the above be not corrective of your concern, pls post back with the make & model of your router, laptop, and the WiFi adapter if external/add-on. Knowing your Operating System would also help.
    Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
    Apr 09, 2008 | Computers & Internet
    Neo M74S Logo
    81 people viewed this question
    Top NEO Computers & Internet Experts
    JonSnell Electronic
    JonSnell Electronic
    Brett Duxbury
    Brett Duxbury
    ray gallant
    Are you a NEO Computer and Internet Expert? Answer questions, earn points and help others
