Hook up a turntable to A Sony STR -DE 135 ? - Audio Players & Recorders
5 Suggested Answers
  • 30 Answers
SOURCE: Can I hook up a photo turntable to a sony str-de435 receiver?
If your turntable has an amplified output, go ahead and plug it in to the aux port. If not, you won't be able to use it with your receiver properly. Look on the back (or front) of your turntable for a knob labeled "level" or "volume", and that will determine if it's amplified or not. Good luck, I hope this helps!
Posted on Oct 19, 2009
  • 4234 Answers
SOURCE: can i use a turntable with the sony str dh500
This particular unit only has 2 line level inputs for audio devices. You can use 1 for the CD player and the other for the Turntable. Please note that you will need a phono pre-amp for the turntable as the inputs on the receiver are line level. The preamp will amplify the phono level to line level.
Dan
Posted on Nov 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Posted on Mar 21, 2010
  • 336 Answers
SOURCE: my sony str de 835 display went out. sometimes
Most likly bad solder connections on the display board. Look for solder rings on the LCD. You must remove the front panel to gain access.
Posted on Mar 22, 2010
Testimonial: "I'm gonna take a look. thanks"
How do I connect my turntable to a str de-675 receiver
Take 2 rca wires a white one and a red one. On the back of the receiver, find a source you are not using( md/tape or aux ) connect red to red, white to white Turn on receiver and on the front, push related button( aux ). This should work. Good luck
Feb 10, 2015 | Sony STR-DE675 Receiver
How to hook up sony str dg600 with a turnable?
Possibly. It depends upon the type of cartridge used by your AT turntable. If the volume is very low, there may not be enough output.
Jun 10, 2014 | Audio Technica AT-PL50 Turntable
Connecting a turntable to Sony STR K502P
Use RCA Cables from the TT to the Aux in on the Receiver. You may need to use a pre-amp inline from TT to Receiver.
http://www.bhphotovideo.com/ has a few.
Mar 17, 2014 | Sony STR-DE485 Receiver
Using an equalizer with a Sony STR-DE 475
I think I must have missed something. Where does the EQ get hooked up to on the Sony STRDE 475? Thanks, Nicolas
Nov 22, 2012 | Audio Players & Recorders
How do I hook up a turntable to this receiver
You should have MD/tape on the back with two phonos. Connect the phonos from turntable to IN slot. You should work
Mar 22, 2012 | Sony STR-DE595 5-Channel Amplifier
Can i use a turntable with the sony str dh500 model? I am illiterate when it comes to hooking this stuff up. Planning to purchase this model only if I can hook up my record player as well as my cd player.
Dan
Nov 17, 2009 | Sony STR-DH500 A/V Receiver
Can I hook up a photo turntable to a sony str-de435 receiver? There aren't any jacks that specifically say phono, so I'm wondering if I can just hook it up to any of the audio jacks without any problem....
Oct 19, 2009 | Sony STR-DE435 Receiver
How do I hook the STR DE 575 up to my tv?
Usually if you have a Cable or Satellite box, you would hook up a Fiber Optic or Digital Coax cable from the Sat/Cable box to the Sony Receiver. Then for HD, an HDMI cable or componet cables from the Sat/Cable box to the TV
Dec 18, 2008 | Sony STR-DE575 Receiver
135 people viewed this question
 Grubhead
Grubhead
