My nettalk duo's red light is constantly on .its not working. how can i fix it.
ANSWER : I have had the solid red light come on every so often. I would power cycle the nettalk and it would be find for a while, then go out again. The solution is to assign the nettalk device a STATIC IP that is outside of the range of ip addresses assigned by your router for DHCP.
Example, my linksys e1200 router by default assigns DHCP addresses starting at 192.168.1.100 and goes to 192.168.1.149. If you assign the mac address of the nettalk to an ip outside that range (that is not 192.168.1.1 because that is your router) like 192.168.1.20 it will solve this issue. whenever the nettalk connects to the router, it will always get 192.168.1.20, I think the nettalk can't handle getting different ip addresses from the DHCP server.
Then tTurn off the nettalk, then do a power cycle on your router.
