Question about Nikon D70 Digital Camera with 18-70mm Lens
Camera works,all lite up and functions work
However when i take a picture using nikkor 35 - 70mm lens, all i get is purple haze and no real picture. i can email picture of problem if needed as not very good at explaining. please help
    Novelist:
  • Nikon Expert
  • 357 Answers
Purple haze usually indicates an image sensor failure. However, the fact that it only does it with one of your lenses is strange.
Posted on May 05, 2013
  • 265 Answers
SOURCE: LCD Screen stopped working on camera.
Have you tried the 'Menu' button? If you've turned off the 'Review' feature in the settings menu, your LCD screen won't show anything unless the 'Menu' button is pressed. If it doesn't come on when you push 'Menu' with a charged battery installed, your camera will need to be serviced.
Posted on Dec 25, 2007
  • 17 Answers
SOURCE: LCD show purple or violet cast on white areas when using auto mode
Have you tried viewing the photos on a computer or printing them? There should also be parts of the menu/setting displays that would be white. The text on the image info should be in white.
If you are getting white, it would suggest your whitebalance isn't set correctly. If everything has a purple tint to it, check your LCD display settings, otherwise it may be the screen is failing.
Posted on Jan 03, 2008
SOURCE: Nikon D80 Autofocus problem
Try re-setting the camera? On the D40 it is 'Menu' scroll down one to Custom Setting Menu (a pencil) and click reset 'ok' yes 'ok' this worked for me.
Posted on Sep 09, 2008
SOURCE: Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Posted on Feb 20, 2009
  • 11967 Answers
SOURCE: D90 and Nikkor 17-55 problem. Lens won't come off
It's obviously in crooked. You will probably have to force it off but there is always the chance of damage.
Posted on Jan 12, 2010
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
What type of lenses fits this camera
Lens mount Nikon F mount (with AF coupling & AF contacts)
Lens compatibility • D-type / G-type AF Nikkor (except IX-Nikkor): Autofocus and all functions possible
• PC Micro-Nikkor 85mm f/2.8D: Usable in Manual exposure mode
• AF Nikkor other than D-type (except AF Nikkor for F3AF): All functions except 3D Matrix Metering possible
• AI-P Nikkor: All functions except 3D Matrix Metering and autofocus possible
• IX-Nikkor: Cannot be used
• Non-CPU: Usable in Manual exposure mode (exposure meter cannot be used)
Electronic Rangefinder usable with lens with maximum aperture of f/5.6 or faster.
Jul 04, 2011 | Fuji FinePix S2 Pro Digital Camera
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Camera will not take picture with nikkor 105mm lens
Check if the lens is properly mounted. If still you get the error message, clean the electrical contacts between the lens and the camera using an eraser. Take care not to let any dust fall into the body. Attach the lens and try.
Feb 10, 2009 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Lumix FX12 LCD screen shows purple haze
raegag
wsd*g
jagskfsda
vwomcjcwkjksdfs;adjkfksjcvijsiarue45646514sd5v13sd4f86vaf21g623g4f861++-+sv+svgsfgsg+fgasvcsdgwg
the answer is 123456789654321456789654123 dota boysssssssssss
Jan 16, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Hello guys fuji film s1 pro problem
From the Fuji S1 Manual:
F-- (Flashing) or (lit in M Mode)
Cause:
The lens mounted is not a Nikkor lens with built-in CPU or no lens is mounted on the camera.
Solution:
Use a Nikkor lens with built-in CPU (excluding IX Nikkor lenes). (Note that pictures can still be taken in M mode.)
Jun 06, 2008 | Fuji FinePix S1 Pro Digital Camera
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Screen shows a fuzzy purple haze
unistall it and then restart computer works like a charm. dont reinstall it, cause for some reason it comes back up when restart it
Nov 18, 2007 | Toshiba PDR-5300 Digital Camera
Nikon D70 Digital Camera with 18-70mm Lens Logo
44 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
