Question about Refrigerators
We have had our Bosch Intelligent Frostfree 40 for 5 years, its always leaked, water running out the bottom of the door, and why are all the clip on additional shelves etc breaking?
SOURCE: Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Posted on Jan 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: Ice repeatedly forms at the bottom of the freezer
Your defrost drain line is frozen up.
Turn off fridge, remove bottom freezer drawers.
Remove visible ice.
Take a hair dryer and melt ice at the back of the freezer at the drain pan.
Pour a water and bleach mixture through drain hole.
This procedure could take a hour or more.
Posted on Feb 21, 2009
  • 3 Answers
SOURCE: Bosch intelligent frost free 44
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
Posted on Feb 28, 2009
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
SOURCE: bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Posted on May 12, 2009
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
LG Dishwasher leaks!! New E1 Code just fixed an HE Code, gasket not broke, one of the electrical connections underneath had come loose so I just clipped it back on. I have not hooked everything up again...
http://lgdishwasher.yolasite.com/ MINE JUST STARTED AGAIN TODAY. SWOLLEN BOTTOM DOOR GASKET LOOKS LIKE HILLS UP AND DOWN. ALLOWING WATER TO OVER FLOW DOOR BOTTOM. GETS TRAPPED BEHIND GASKET. PAN HAS LITTLE WATER WHEN YOU OPEN DOOR. BUT CAN SEE RUN OUT OVER EDGE WHEN RUNNING WITHOUT OUTER DOOR SKIN, ALSO LEAKS AT TOP CORNERS DUE TO DEFORMED CORNER GASKET. THEY SHOULD HAVE MADE THE GASKET ROUND IN CORNERS TO KEEP IT SEALING, HAD TO MAKE C METAL CLIPS 4 INCHES LONG TO HOLD BOTTOM GASKET TIGHT TO BOTTOM PAN, USED 4 CLIPS AND TWO SMALLER AT ENDS
Oct 18, 2013 | LG LDF6810ST Stainless Steel Built-in...
Bosch Intelligent Frost Free 44. Freezer on top. Water leaking at bottom of front door. What is the cause of this problem and how can it be fixed.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 07, 2011 | Bosch KSU49630 Top Freezer Refrigerator
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Dishwasher leaking
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Jun 30, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Leaking door on front loader bosch washer
Make sure latch mechanism is tight and check out the seal for imperfectionc ....ie cracks or flat spots
Jul 22, 2017 | Bosch Washing Machines
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
