Question about John Deere Garden
Only runs full choke and lacks power - John Deere Garden
  • John Deere Master
  • 7,482 Answers
Hi John
Posted on May 03, 2013
Ryobi 80930 washer. Got it last year has only been used a few times. Inside during winter fuel was drained,only runs on full choke,cleaned the carb,spark plug, new fuel and had no affect. Any advice?
on runs on full choke indicates a blocked main jet or lack of fuel
I would pull the carby and replace the diaphragms or make sure that the gasket is on the right side of the diaphragms
if you used e- fuel mix then the diaphragms will be damaged
check around before buying parts as a new carby is now cheaper than parts to fix it
Jun 01, 2016 | Ryobi Garden
95 suzuki 250 quad king, at full throttle it runs at half power, choke seems inop
First make sure your choke circuit is working. May be an indication that your carb needs to be cleaned. I wouldn't replace it yet= clean it. If the choke circuits and the carb check out fine. An unresponsive motor/ carb usually means bad valves or valve timing. Example: it runs rich, spits fuel out the carb no matter how lean you set it. Even with the idle air closed it runs rich... intake valve is not closing or closing late. In that case it needs valves serviced.
Aug 26, 2014 | Motorcycles
Lacks power, choke will not go full
some of you guys really ask bad questions, provide little details so don't be suprised if no one can give you a answer. i don;t know try draining the old stale fuel out and replenishing with fresh, check basic stuff like clogged air filter, or in line plugged fuel line. the thing needs fuel, air and spark to run in the proper amount, test the plug too for fouling and proper gap. but sound like its likely a fuel problem
Aug 13, 2014 | Garden
I need help with my B/S Engine. Lack of power and black smoke coming from the exhaust.
If the plugs are ok and your engine is not smoking after starting and running ..Sounds like either of three things..all with the carburetor .First the carb has a adjustment screw for air/gas mixture on the side if the carb where it attaches to the engine..try this start the engine and at about half throttle..now adjust the screw clockwise until the engine starts to miss and bogg down then back the other way until it starts missing and bogging again. Then slowly adjust back and forth until you hear the engine run the smoothest..give it more throttle if it starts to run rough do the same procedure until you get the results you want..if it is the mixture problem this will take care of it..if this doesn't it it may be your fuel jet in the bowl dirty or the blow float sticking..if you are not familiar with carbs best to have a professional look at it..you can drop the bowl by removing the bottom bowl and clean it out...check to see if the float easly moves up and down..replace the bowl and go from there..worse scenario new or rebuilt carb...good luck..
Jun 07, 2014 | Briggs & Stratton Garden
Engine only runs with choke on. Blue smoke comes out and engine runs rough or not at all
sounds like you have a bad Ring on the Piston or a blown head possibly. Blue smoke means Oil is getting into the combustion chamber. Full choke means you have to give this 'broken' engine a lot of gas to compensate for it's problem.
Do you change the oil at least once a year? Filthy oil or a lack of oil will kill an engine
Aug 06, 2012 | Yard Man Garden
Honda gcv530 lack of power, spluttering
pull the fuel line from the carby and check the fuel flow through the tap
if it is not a full on flow , it is possible that the filter in the tap in the tank is blocked or the internals of the tap are corroded preventing full flow
what you have indicates a flow restriction and the float level is getting too ;ow for the engine to run properly
do not use e-mix fuels as that causes rust or corrosion of metal parts
Jun 24, 2017 | Garden
Virago 535 lack of power!
Clean the jets out and try readusting them, if it has sit for a while gum can build up on the needle and seats so they need to be cleaned. also make sure you don't have a problem with fuel line fuel shut off valve make sure fuel is flowing to the carb and be sure air filter is clean. ake sure the carb is tight and the gasket does not have a hole in it or cracked. let me know if you need more help.
Aug 07, 2009 | 1988 Yamaha XV 535 Virago DX
2001 elantra lack of power
Confirm ur fuel pump is working. Ensure ur pickup tube is not blocked. Then ensure u did not leave a rag or parts in the manifold tubes. Not laughing it happens. Is the distributor in the right spot. Etc etc. Did u rehook the alt up if removed . Is tje battery fully charged. And lastly is the fuel flowing and freash. Then recheck your work did u replace all parts right. Any air in the head gasket will make the fuel /air mixture off.
Good luck
Jul 16, 2017 | 2001 Hyundai Elantra
Garden Logo
102 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
