Question about Starrett 2600-0 65593 - 2600-0 No. 2600 Series , Electronic Digital Indicators, Basic Model, .0005" 0.01mm Resolution without Output
Error code 4 on a Starrett 2600-1 electronic indicator
Error code 4
2 Suggested Answers
  • 436 Answers
SOURCE: How can I switch from
Should be pretty easy.
On the top row of buttons, the one with the "DOT" on it is the In/MM button.
Press that and it should change from inch to metric.
I hope this helps
Thanks
Posted on Apr 20, 2011
Where can I get a user manual?
cannot find manual but button with 'dot' changes from in to mm
Apr 05, 2016 | Starrett 2730-1 Electronic Indicator,1...
How do i shut off my starrett electronic slid caliper?
Hello there
From the manual here
http://www.starrett.com/docs/other-downloadable-resources/798-electronic-slide-caliper-user-manual---form-951.pdf?sfvrsn=3
Automatic shut off of display after 30 minutes of non-use
Reactivation of display with movement of slide with no
loss of position
Sep 24, 2014 | Cars & Trucks
What does E6 error code mean
here is basic error codes for your dryer (and how to get them out)
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 04, 2014 | Frigidaire Dryers
What is the correct battery for the starrett 723 electronic caliper
If small button cell then sr44 battry& if big button cell use cr2032
Jan 25, 2014 | Starrett Electronic Caliper
Starrett no 731
Are you certain the battery is installed correctly? Many electronics won't work if the battery is installed backward/upside down. Do not ask how I know this....[-:
Jan 15, 2014 | Cars & Trucks
Shut down starrett 733
On some Starrett calipers, there is no way of turnig them off, which means about once a year you have to replace the battery. sorry
Jan 22, 2013 | Starrett Electronic Caliper
How do you change batteries in the starrett 3752 heighth gage. I dont have a manual or intruction book
Hello rdm56us, Sorry for the delay but copy the follow link for change your battery, you have need 2 CR2450:
http://www.starrett.com/docs/user-manuals/3752-electronic-height-gage---form-578.pdf
best regard
Apr 28, 2011 | Starrett Garden
How can I switch from inch to metric on the Starrett Electronic Indicator # 2730-1. Thanks, Rick
I hope this helps
Thanks
Apr 20, 2011 | Starrett Garden
3"-4" Starrett 436 micrometer: When spindle
do you still have the locknut wrench? you need to loosen the spindle. if not try an industrial supply store to get wrench.
hope this helps
thanks
Mar 25, 2011 | Starrett Garden
Starrett 2600-0 65593 - 2600-0 No. 2600 Series , Electronic Digital Indicators, Basic Model, .0005" 0.01mm Resolution without Output Logo
178 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
Vernon Taylor
ray gallant
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
