Question about Frigidaire FGHG2344MF Bottom Freezer French Door Refrigerator
Right door flap not hugging door when ioening left door with right door already open
When opening right door with left door already open the flap on the right door does not fully pivot flush with the right door. This causes a problem when closing the left door first and then closing the right door The flap on the right door jams against the left door and prevents it from closing.
    Top Expert:
  • Frigidaire Master
  • 45,139 Answers
The doors have to be adjusted. They may have moved out of their intended alignment over time
Posted on May 01, 2013
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Posted on Nov 20, 2008
  • 1218 Answers
SOURCE: need to turn doors around
Good day,
Start from the top and work down.
Make sure all items are removed from both doors, and machine should be shut off.
1. Remove top bracket with the freezer door still shut.
With both hands, open freezer door about 1 foot, and lift off.
All thru this process keep track of all shims and washers and their location.
2. Remove center bracket holding main door and remove using the same process as with the freezer door.
3. Remove bracket from the bottom and reverse to the other side.
There will be a lot of press in buttons to be removed by prying them out with a small screw driver.
4. Reinstall in reverse order, making sure all shims and washers go back where they came from. As well, Tighten screws while making sure the door is in alignment at the same time.
5. Remove both door handles and reinstall. Some screws may be hidden by a cover that will have to be pried away first.
Posted on Nov 25, 2009
  • 441 Answers
SOURCE: Freezer door slightly ajar
This happens alot, it can be helped by coveringthe door gasket of the freezer side with vaseline, this will increase the hold of the freezer door. You want to apply it to the flat side of the gasket where it makes contact with the case
Posted on Jun 08, 2010
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
Tip
VAG COM Fault Codes
ERROR CODE (DECIMAL) - CODE ERROR - ERROR CODE (OBD II) -The description ERRORS
00000 0000 O End
00001 0001 braking system control unit
00002 0002 gearbox control unit
00003 0003 control unit
00004 0004 control unit for engine gas-J659
00016 0010 Vers. electric space heater, rear right damper leg / defroster-V195
00017 0011 Vers. electric space heater, rear left footwell flap / defroster-V196
00018 0012 Executive electric cold air flap-V197
00019 0013 Executive damper motor warm air-V198
00020 0014 Executive electric Right flap and defroster vent-V199
00021 0015 Executive electric left flap and defroster vent-V200
00022 0016 Executive electric right hot air flap at the rear of the center console-V201
00023 0017 Executive electric left hot air flap at the rear of the center console-V202
00024 0018 Executive electric right cold air flap at the rear of the center console-V203
00025 0019 Executive electric left cold air flap at the rear of the center console-V204
00026 Executive 001A motor Right flap and defroster vent-V205
00027 Executive 001B motor left flap and defroster vent-V206
00028 001C Executive electric left bezel-V207
00029 001D Executive electric central bezel-V208
00030 Executive 001E motor right bezel-V209
00031 001F defrost key left rear glass-E299
00032 0020 defrost button the right rear window-E300
00033 0021 Control button front left deflector-E301
00034 0022 Control button front left center vent-E302
00035 0023 Control button front right center vent-E303
00036 0024 Control button right front baffle-E304
00037 0025 Key for adjustment of the temperature difference between the space for the legs and the upper part of the cabin-E305
00038 0026 Control button left rear deflector in the center console-E306
00039 0027 Control button right rear deflector in the center console-E307
00040 0028 lock button door opener inside-E318
00041 0029 Executive damper motor uniform air flow-V213
00042 Lamp 002A left hand fire-M43
00043 002B lamp right hand fire-M44
00044 002C Perform test 1 group of actuators
00045 002D Check Now 2 groups of actuators
00046 002E Electric retractable washer jets left headlight-V248
00047 002F motor sliding washer jets right headlight-V249
00048 0030 heat exchanger temperature sensor, left-G306
00049 0031 heat exchanger temperature sensor, right-G307
00050 0032 temperature sensor-G308 Evaporator
Full list of fault codes here
Car Manuals PDF
on Dec 20, 2016 | Cars & Trucks
Where is the ground coffee shoot?
Open the door and you will see four bins top right is the bean container - bottom right is the water container - bottom left is the waste container - top left is and empty storage bin - remove the top left bin and you will see a flap door - lift the door up and insert your ground coffee.
Jul 18, 2014 | Miele CVA 4066 Stainless Steel
Renault modus fual door wont open
Fuel flap actuator has failed to open simple open trap door in boot right hand side panel inside you will see a black box approximately 10cm by 7 cm with a hook that can be pressed upward to open the flap
Jul 13, 2014 | 2005 Renault Modus 1.5
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
Glove box door flaps all the way down when I open the glove box.
Look up inside the right or left side of the dash where the glove box closes. There should be a screw that holds stop your talking about. Re attatch it. Unscrew the screw. If broke then use a small nylon strap n secure it to that screw n to the place on the inside of the glove box door.
Sep 24, 2012 | 2005 Cadillac Deville
The door is stuck
Link to the manual...
http://www.miele.co.uk/Resources/OperatingInstructions/W%20320.pdf
Open the flap covering the drain plug on the lower left of the machine (there#s a plastic tool to lever it open stored on the inside of the soap dispenser drawer).
Now the flap is open, you will see a small circular toggle handle. Pull this down, and the lock should pop open.
If you have water in the machine, this will now spill out unless it has already drained. If you need to drain water, place a tray under the circular plug you have uncovered and slowly unscrew it.
Jun 29, 2010 | Miele W320 Front Load Washer
Gasket on Rght side of French Door Fridge
well I suggest you and your neighbor both call Jenn Air as they now have 2 known complaints and perhaps more if others read this and check theirs as well
Jan 28, 2010 | Jenn-Air Pro-Style JFC2089H French Door...
I'm not sure where the lever/button inside the car is to open the bonnet
On the driverside right above the handle to open the hood.
Dec 22, 2009 | 2001 BMW 5 Series
Frigidaire FGHG2344MF Bottom Freezer French Door Refrigerator Logo
255 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
