Dell broken keyboard ribbon cable connector
Is it possible to take out keyboard ribbon cable connector out from dead dell laptop and fix it to my laptop
  • 7,627 Answers
Why not just change the keyboard, ribbon cable and all? Or are you referring to the connector on the motherboard? It can be done, if the motherboards are a match. Do you have someone with the skill to do it?
Posted on May 02, 2013
  • 32 Answers
SOURCE: keyboard connector on motherboard dell inspiron2200
personnally I would not try this. If this is the only laptop you have. now if its just a machine you tinker with you can try it. but for functunality I would leave the keyboard intact incase you ever want to use the portability of the laptop.
Posted on Apr 16, 2009
RescueTechLA
  • 2653 Answers
SOURCE: connector for keyboard on a acer travelmate 4220
I just call it the annoying super thin and fragile piece of plastic that holds the cable in place.
You CAN'T get it anywhere. The ONLY thing you can do is try to find another dead motherboard on eBay for parts.
When you do get a board be very VERY careful when you try to remove it from the dead board. If you even look at it the wrong way, it will break ;)
Best of luck!
--RescueTechLA
Posted on May 12, 2009
  • 4 Answers
SOURCE: Broken touchpad connector
I suggest you replace the motherboard. A recent search on ebay turned up three ranging in price from $18 to $85. Soldering a motherboard by hand has a very high failure rate. It's easy to bridge or scratch something and fry the board. You could of course try to do it and if it fails get a replacement board.
Posted on May 28, 2009
  • 253 Answers
SOURCE: How to Get a good Dell Latitude D520 Laptop
it sounds like you did the right thing, i would search google for "Dell D520 keyboard", you should find many places at different prices, if you havent bought from the site before, try reading some customer feedback, and also, the cheapest may not be the best, look for a good return policy and or warranty for the item. if this helps pleas give a fixya rating thanks
Posted on Jul 19, 2009
SOURCE: replacing the keyboard
This is the link to the R4000 (and ZV6000) Maintenance and Service Manual. It has detailed instructions on how to disassemble and repair the computers.
http://h10032.www1.hp.com/ctg/Manual/c00364919.pdf
Hope it helps!
sdw
Posted on Oct 11, 2009
Dell Inspiron N3050 eyboard not reconnecting
You're talking about the keyboard connector on the laptop's motherboard, that the ribbon cable attaches to, or an external keyboard?
Oct 15, 2014 | Computers & Internet
Removing the keyboard broke the plug
Never have seen a Keyboard's Flat Flex Cable, that had a connector on the motherboard end. http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The motherboard connector is a type of ZIF connector. Zero Insertion Force. It is composed of TWO pieces, but DOES NOT come completely apart.
The bottom piece is the BODY. The top small piece is the Locking Bar.
IF, the Locking Bar is broken off, you may be looking at MOTHERBOARD REPLACEMENT.
http://www.laptoprepair101.com/laptop/2009/11/17/fix-broken-keyboard-connector-on-laptop-motherboard/
Regards, joecoolvette
Aug 31, 2012 | Acer Aspire One D270-1824 Aod270-26dkk
Tx2 keyboard zif connector broken
Hello i ran into this problem twice with a Toshiba and a hp what i did was go through my parts found an old laptop keyboard and cut the ribbon cable from that folded it over to make it twice as thick and worked it into the groove then i slid a piece of credit card into the middle of the folded cable like a sandwich the credit card shim was the meat and the folded ribbon cable shim the bread put a piece of tape on top to keep it secure never a problem take a breath think about it and dont use force or glue the mind is a powerful thing use it this does not mean mother board replacement
Jul 19, 2012 | HEWLETT-PACKARD HP Touchsmart TX2...
Dell mini 1018, upgraded memory to 2gb, worked fine except ribbon cable connector broken. Where can I get another 1 cent piece of plastic, or should I just use a usb keyboard?
I encountered a novel way to resolve that issue on an Inspiron 1110, where the person working on it had also broken the Keyboard cable connector clip. They used clear packing tape to hold the ribbon cable in the connection. It may take some diligence, but you may be able to get a decent cable connection that way.
Jul 12, 2011 | Dell Mini 1018 Notebook
How to change the keyboard on dell studio xps 1645
You have to remove the palm rest ( the top part that has the keyboard and touch pad) to access the 13 screws securing the keyboard and shield which are underneath the palm rest. This involves removing the bottom access cover, rear caps, remove ten screws that are marked with a small P on base of computer. Remove two screws that are marked with a K. Remove two flat-head screws in the battery compartment. Then flip the system over. Remove the two screws at the top of the palm rest. Pry the palm rest loose with your fingertips, starting at one edge. Flip open the latch on the keyboard ribbon cable connector, and remove the cable. Lift the latch on the touchpad ribbon cable connector, and remove the cable. Remove the palm rest.
Feb 15, 2011 | Dell Studio XPS 1645 Laptop
My dell computer's letters a,s,d,f,j,k,and l don't work
hi,
best solution is to replace your keyboard.
Feb 04, 2011 | Dell Computers & Internet
The letters "b" and "n"
there are programs you can use to erase the password but it is very easy to replace the keyboard.
I would suggest you type buy Dell Inspiron keyboard in to google an do the same on Ebay.
I did this for my friends laptop, the keyboard cost less than 10 pounds and had 2 ribbon connectors to remove the coffee stained old one.
You will need to buy some micro screwdrivers to open up the laptop.
No special skills are required to change keyboards, just give yourself a good bit of room on a desk to have the removed screws to hand.
Nov 30, 2010 | Dell 0Y3740 Keyboard
Replacing the keyboard
your only supposed to pull the hinge out carefully a small amount so the flex cable comes loose, then insert the new keyboards connector there and push them back into place. Its pretty much the same thing in all brands of laptops.
if you have broken the connector, you will probably be looking at buying a new motherboard unless you find someone to replace the broken connector.
Oct 11, 2009 | HP Compaq Presario R4000 Notebook
I have a problem with the keyboard on Dell C600 laptop. It seems like the left part of the keyboard is disabled. No respons on 1,2,q,w,a,s,z,x,Esc. I purchased a new keyboard on eBay, but it didn't fix the...
The C600 keyboard connector is a ribbon cable with a push down to connect block. When one side of the keyboard keys do not work it is usually because the pins in the keyboard socket do not make a good contact with the ribbon cable.
Remove the keyboard and visually inspect the pins in the connector.
If necessary you can prise them back into the correct position using a sewing needle or something similar to get behind the pins.
Make sure you discconect the power supply and battery before you attempt.
Jul 31, 2009 | Computers & Internet
Keyboard connector on motherboard dell inspiron2200
Apr 16, 2009 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
