Question about Fisher and Paykel Dishwashers
Customercare Why do my glasses streak? I am using Finish Powerball tablets.
  • Fisher and P... Master
  • 3,247 Answers
Generally what type of detergent you use depends on what is recommended for the dishwasher. I am not sure which model of fisher and paykel dishwasher you have. But my opinion is that dish drawer type dishwashers work better with normal Finish powder detergent. It is not designed for tablets. The size of the wash space is small and it works on the principle of short and quick wash cycles. So the powerball is an overkill. Now about the streaking, this could be linked to the powerball but also you need to check if the rinse aid is present in the dispenser and also that you have selected the appropriate meter level for it being dispensed. 0 means no rinse aid and 5 is too much.;
Posted on May 02, 2013
eagle338
  • 4889 Answers
SOURCE: Any reported problems with new Finish Quantum Powerball tablets
Yes there have been some issues with these stuff in dishwashers without flood protection. If you want to use them you will have to get a anti-flood attachment for your washer. So its up to you to decide..
Posted on Sep 29, 2008
garing
  • 998 Answers
SOURCE: Not cleanng well
try hotter water
Posted on Aug 16, 2009
mgprice
  • 744 Answers
SOURCE: When using dishwasher the
Hi, the problem here is going to be with the heater. the water inside the machine should be 140f in order to disolve the detergent. you should check the heater with an ohms meter. should read infinate. If as i suspect its bad you should replace it. Mike
Posted on Nov 23, 2009
woodchuck789
  • 4070 Answers
SOURCE: Glasses not clean and shiny
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Posted on Jul 06, 2010
national_a_r
  • 148 Answers
SOURCE: I have been using finish powerball tablets. Of
Make sure you have at least 125 degrees coming into the dishwasher.
Posted on Dec 11, 2010
My goldseries whirlpool dishwasher is not cleaning dishes. Grey film left on glasses etc and cups are not getting tea stain off. I just bought large box of Finish Powerball
I have not had good luck with all-in-one soaps. I use the liquid drying agent with Cascade Complete and get sparkling results without prewashing. They do need to be rinsed if they have sat for a while before running the washer and use the hottest water to warm up the water in the washer pipe before you start the washer.
Jun 05, 2017 | Whirlpool Dishwashers
Where do I put the Finish powerball in my KENMORE 24 in built in dishwasher? There are two places to put the soap. One has a cover and the other does not.
If you have a water softener, just drop the entire tablet into the bottom of the dishwasher at the beginning of the cycle. This is to allow extra cycles to get all the soap out, since soap goes a lot farther in soft water. If you don't have a water softener, put the tablet in the part with the lid, and close the lid. You don't need anything in the other (pre-wash) part.
Aug 03, 2014 | Kenmore Dishwashers
I have a fairly new Fisher and Paykel double drawer dishwasher. A problem has developed all of a sudden whereby the Finish powerball tablet does not completely dissolve during the cycle (top drawer only),...
The water temperature is not coming up to the required level. The heater might be failing. Will need a technician to fix unless you are very savvy with technical repairs. Have you tried using the detergent powder in the dispenser to find if results are different.
Feb 05, 2014 | Fisher Dishwashers
What is the most effective soap for thw Miele G870SC diswasher
the only dish detergents that work right now are the miele tabs, and finish has a product called finish all in 1 powerball. everything else on the market right now will leave your dishes dirty, and will leave residues behind making your glasses cloudy and your dishes dull. describe the noise better and i will try to help.
May 31, 2012 | Miele 24 in. G870 Built-in Dishwasher
Which is the best powdered cascade product for the china/crystal setting on my miele?
Most european dishwashers are water conserving and energy saving. You have to be very careful in the type of detergent that you use. Plain, original cascade powder works fine in your Miele. Use 1/2 of the recommended amount, as your dishwasher uses much less water than the american machines that the amounts are written for. avoid cascade with additives such as bleach, or dawn. these additional components in the detergent do not rinse off well with the reduced water quantity, and will leave a gritty white residue on your dishes. Stick with the plain powder. I use Finish tablets with the red powerball, and I dont add rinse aid. These tablets work great in the Miele, asko, Bosch, and other imported dishwashers.
One caution on your china and crystal setting, your manual states that if you want to use the china and crystal cycle, the dishwasher should be connected to cold water only. The temperature of the china and crystal setting is limited to 115 degrees. your hot water is probably much hotter. if your dishwasher is connected to hot water, it will defeat the purpose of the lower temperature cycle. you will get etching on your crystal glasses.
Remember, the Miele will heat its own water one batch at a time. Connect it to cold for energy efficiency, hot for shorter cycle times. but cold only for china and crystal.
Enjoy your machine.
Nov 18, 2010 | Miele G2183SCSFSS Builtin Dishwasher
Sep 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
189 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
