LG GCE 8481B CD-RW Burner
Problem for LG GCE 8481B CD-RW Burner
Weird Error From CD/DVD Drive
By Killarmy on Aug 08, 2007
ERROR:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click Troubleshoot to start the troubleshooter for this device.
I'm not sure what is causing this error, but I have tried Windows Updates as well as uninstalling the driving and installing it again, but still no luck. I have even gone as far as "troubleshooting" the problem, but no luck there either. Might anyone have a solution or any solutions to the error mentioned above?
Same Problem
Jul 06, 2008
-   I've only just installed Windows XP Office on my new Packard Bell PC (Windows Vista) and suddenly the device driver of my DVD/CD-ROM-drive was declared to be corrupted (or missing). Comment:
What can I do?-   wabuba
Best Solution
posted on Aug 08, 2007
Very Helpful)
jmorgan123
Rank: Guru
Rating: 90%, 1059 votes
Was this helpful?
Yes
No
Solution #2
posted on Apr 23, 2009
Very Helpful)
dilipbagdi
Rank: Guru
Rating: 88%, 1437 votes
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 18, 2008
Very Helpful)
hardkiss69
Rank: Wiz
Rating: 92%, 83 votes
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for LG GCE 8481B CD-RW Burner
Questions and Unsolved Problems for LG GCE 8481B CD-RW Burner
Do you recommend LG GCE 8481B CD-RW Burner?
Answer
Answer
Can i use dvd-rdl disk for an RW AD-5170A ATA Device burner?
Answer
My computer gives me this message, " "Windows cannot load the device driver for this... (More)
Answer
optiarc DVD RW AD-5170A i think i need to update because he don't read a dvd he dont write and he... (More)
Answer
Unused CDs and DVDs show as full when I go to My Computer>DVD RW Drive> Properties. Is this a... (More)
Answer
In my device manager it shows the DVD with an explanation point. When I update, it says the device... (More)
Describe your CD and DVD Burners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
in , MN
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
