Question about Frigidaire Kitchen Ranges
Instructions on Self Cleaning Oven model RE34BA REG 36A REG 36CA RSE37 BA RSE-37BAL
Frigidaire models RE34BA REG36A REG36CA RSE37BA instructions for self cleaning oven. Taken from owners manual:
Setting the controls:
1. Close the oven door
2. Make sure the clock shows the correct time of day.
3. Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will thin clock out.
4. Set the Stop Time for 2 to 3 hours past the Start Time. EXAMPLE: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00.
5. Set the Temperature Control to CLEAN.
6. Set the Selector to CLEAN. The door will lock and the oven signal light will come on. The oven signal light will stay on until the oven reaches its cleaning temperature. The clean light will come on when the oven temperature reaches approximately 550 degrees. The oven signal light will then cycle on and off to show the temperature is being maintained. It will then go off at the end of the cycle indicating that the high temperature phase is completed.. The oven must now COOL FOR ABOUT 1 HOUR or until the interior temperature has dropped below 550 degrees. Only then can the door be unlocked. The clean light will remain on until the oven cools below 550 degrees.
  • Peter Fixya May 01, 2013
    Solution with corrected spelling errors:
    Frigidaire models
    time on the clock. The knob will then pop
    out.
    5. Set the
4 Suggested Answers
SOURCE: Whirlpool Accubake - Can't get out of clean mode
cannot get out of clean mode, although the oven outside is cool, but door is locked and display still says cleaning, door locked and time of 3 hrs 15 min is displayed. NOW WHAT?
Posted on Nov 17, 2008
  • 1891 Answers
SOURCE: After self cleaning cycle was completed and the
you may have blowen the hi limit to oven . not uncommon after self clean cycle .. if digital oven / shup power off for 5 min then reset. and try again ..
Posted on Dec 02, 2009
heatman101
  • 43501 Answers
SOURCE: SELF CLEANING WILL NOT ACTIVATE, GE XL44 MODEL JGBP32AES OVEN
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 09, 2010
How do I clean my Frigidaire electric oven, Model FEF352AWF?
See page 13 for specific instructions.
ShopYourWay FRIGIDAIRE Free Standing Electric ShopYourWay
As tedious as it may seem I suggest that cleaning the unit by hand is the preferred process. Most failures that I have experienced have occurred just after the clean cycle is completed. There is a lot of stress during self clean and critical components are stressed and are more likely to fail. On two occasions I have had a failure days before family dinners. Usually in preparation for family we had been cleaning the oven. Both the temperature sensor and heating element have failed.
With a free standing oven repairs are a lot easier than with a built in wall oven requiring saw horses to remove and set. In any case plan to clean long before company in the event a repair results.
Why You Should Almost Never Use Your Oven Self Cleaning Function
Jan 06, 2016 | Frigidaire 30" Self-Cleaning Freestanding...
What is wrong with my frigidare self cleaning oven model #RSE-37BAL*O that heats hotter than the set temperature. Does it need a thermostat or ?
I appreciate your post, friend!
It sounds like you made need to replace your thermostat or control panel on your Frigidaire range. I would recommend reaching out to a professional for proper diagnosis. Some of these intricate part replacements do require precision and patience, therefore when replacing such components or removing them from your appliance, I would suggest seeking professional assistance. One must be very careful as there certain replacement parts could result in potential harm. Best regards. -Matt
Sep 29, 2014 | Frigidaire Kitchen Ranges
How to use Frigidaire self cleaning instructions lost manual
Good Afternoon friend, thanks for your inquiry!
To locate instructions regarding self-clean on your Frigidaire range I would need to have your model number. I have provided a link for you to use once you have your model number to locate any Use and Care Guides available on your current appliance. I hope this helps to some degree and if you need assistance please reach back out. -Matt
Sep 27, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Model CGLEF379GSA self-cleaning stove with ES340 Control: Won't self-clean after following instructions in manual.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 04, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire Model FED387CHSC Serial # NF01112534. I cannot find the manual. I need instructions for cleaning the oven.
http://www.retrevo.com/support/Frigidaire-FED387CHSC-Ranges-manual/id/2364ci257/t/2/
click on the above link it will take you to a site were you can download the manual for free
Jun 25, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
Frigidaire gas wall oven
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire electri clean selfcleaning feature
It locks automatically. You can download the manual from Frigidaire here (as I just discovered while trying to figure out how to use the self-cleaning feature :) ): http://www.frigidaire.com/support/manuals.asp?NewSearch=New+Search
You don't need to type in the whole model number. For example, if the model number (found in the upper left when you open the oven door) is RSE37BAW*4, you only need to enter RSE37BA.
Apr 27, 2008 | Frigidaire Ovens
Self cleaning oven instructions
I tried pressing clean then the up arrow. Nothing. THEN I HELD DOWN THE UP ARROW FOR A FEW SECONDS AND 3 HOURS CAME UP AND it worked and my oven is now cleaning itself. Remember...HOLD DOWN the up arrow for a few seconds and it will work
May 26, 2007 | Frigidaire FEF352 Electric Kitchen Range
Kitchen Ranges Logo
173 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
