I can not fire up Makita dpc6200 a spark fuel comes I do not know what to do
Hi Marek
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in and be sure to install it in the same position
Normally the clearance is around .10 thousandsands
Also write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Testimonial: "I read everything that I have written dziekuije for instructions already is grasped with life I would like to say that the spark is yellowish orange and this is the reason that I can not smoke a Makita"
SOURCE: Kia ora, i have a
Engines need 4 things: Spark, compression, fuel, exhaust
1) Does spark plug have spark?
Take out plug, put plug wire back on plug, hold plug threads against metal part of engine, pull cord, do you see spark between plug and engine?
2) While spark plug is out, put finger over hole and pull cord. Do you feel suction that shows compression?
3) What about the exhaust port? Is the screen blocked with carbon deposits and dirt? Soak it in WD-40.
4) Do you have 2-cycle oil in gasoline? Do you have fresh gas? Did you leave gasoline in tank for several months? Is the carburetor clogged with gum?
5) What about the air filter? Does it fire up without air filter? Will it fire if you spray WD-40 into carburetor? Can you keep it going while spraying WD-40 into carburetor?
If it fires with WD-40 but won't keep going on it's own, then the gas is not getting to carburetor or carburetor is clogged with gum.
SOURCE: chainsaw makita dcs 340 was running fine until i
The pull cord shouldn't have anything to do with your problem.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spraywith carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
SOURCE: ZAMA carb fitted to Makita chain saw which way
Hello Gordon; We need the complete make, model, and serial numbers with every question in order to fully help you. The IPL for the DCS510-18 can be found on this page: http://www.makita.ca/index2.php?event=tool&id=361&catid=40 Fuel line routing while pictured isn't clear. In the US of A these are red and called Dolmars. A local dealer may allow you to look at his shop manual if one exists. Sorry to not be helpful. Lou
You must help us if we are to help you!
SOURCE: makita 520 chainsaw chain carnt get the right chain
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
An Oregon part Number can easily be converted to other manufacturer's. HTH
Lou
SOURCE: how to remove chain drive on makita Dcs6401-20?
HI , FIRST UNDO BOTH SIDE COVER BOLTS ON THE CHAIN COVER AFTER MAKING SURE THE CHAINBRAKE IS IN THE OFF POSITION,[BRAKE LEVER PULLED BACK].TAKE THE TWO NUTS OFF REMOVE THE COVER,LIFT THE BAR SLIGHTLY AND PUSH IT TO THE REAR.THAT WILL LOOSEN THE CHAIN SLIP THE CHAIN OFF THE BAR AND REMOVE THE BAR ,ONCE THE BAR IS OUT OF THE WAY ,YOU TAKE THE CHAIN OFF THE SPROCKET BEHIND THE CENTRIFICAL CLUTCH AND SLIP IT OUT AROUND THE BACK. AFTER CLEANING EVERY THING ,PUT IT ALL BACK THE SAME WAY .YOU WILL HAVE TO SCREW THE ADJUSTER BACKIN SO AS TO EASILY FIT THE BAR TO THE ADJUSTER PIN ,IT IS NOT DIFFICULT AND AS YOU SEE THE PARTS IT WILL FALL INTO PLACE
