Question about Garden
Mitox 250-c strimmer pull cord
Having trouble getting pull cord to contact shaft looks like something's missing
  • 2,239 Answers
The starter pulley looks fine, however the small starter pawl and spring is missing rom the starter cup on the crank, it should be retained with a c clip from behind the cup
Posted on May 09, 2013
Mcculloch 250 LS strimmer pull start jammed inside and wont move
Recommend you contact your nearest authorized service center, or contact the manufacturer directly by clicking here:
User manuals
Aug 13, 2017 | McCulloch Garden
Mitox 28lhr long hedge trimmer does not start properly. It takes at least 50 pulls of the start cord before it starts. I've changed the spark plug but to no avail. Any advice on how to help it start
  1. Switch machine to On position.
  2. Switch choke to full.
  3. Pump the primer bulb 5 or 6 times to prime the carb.
  4. Lock the throttle on with the throttle switch.
  5. Pull over until engine fires. (it may only be a quick pop)
  6. Switch to half choke.
  7. Pull over until engine starts and runs.
    Also check the air filter is clean and the fuel filter is good.
    I've added a link to the manual incase you didn't have it. Page 30.
    http://www.mowerspareparts.co.uk/v/Mitox%20manuals/271MT281MT.pdf
Apr 09, 2016 | Garden
PP300 Grass Strimmer. There is something jamming the head between the drive shaft and head - underneath the fan. I think it is a piece of string wrapped around the drive shaft. All attempts to remove...
Hi chris. The head is removed like this. You get a suitable spanner to go on the nut behind the head where the cord goes and it is held tightly. The cord head screws off clock wise. You may be able to use some lubricant spray first to help free it up.
Aug 29, 2013 | Garden
Pull on cord for weed eater y 28 yard machine hard to pull how do i repair it
Hmmmmm. The question is why does it pull hard to begin with? Did the pull cord get wrapped around the pulley in an awkward manner or is the machine seized up? If it's not to difficult, pull the muffler off the machine and look at the piston. If it looks scored (lines up and down the piston through the rings) It's shot and probably not worth fixing. But, If everything looks good, then I'd pull the starter assembly off and see if there's something going on there that's doesn't look right.
Sep 23, 2012 | Garden
Husqvarna 325L x-series pull cord repair.
From my experience, the trick is to pull the cord all the way out, then attach the pull assembly to the engine, and let the pull rope win back in place. hope that helps.
Aug 28, 2012 | Cars & Trucks
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
My Husqvarna 128LD pull cord doesn't engage
Possibly the recoil starter pawl's on the inside of the recoil housing not engagning with the flywheel.
Nov 11, 2011 | Husqvarna Garden
Just got a Worx GT151 trimmer. For trimming grass has worked fine. Problem is in edging the sidewalk. I start edging and it takes littleraly 2 seconds to wear the string to half it's length, needing to...
Hi Dave.
When you are using a strimmer against stone or concrete you have to just barely allow the tip of the line to touch the ground. If too much of the line slaps off the concrete, any sharp edges or roughness on the concrete will tend to snap it. What you could try is heavier gauge strimmer line which might last longer. I used to use petrol strimmer line on my Black and Decker strimmer which was 350 watt rated. I'm not sure what effect it would have in the long term though and may wear the bearings due to the extra weight.
Jul 04, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I have just replaced the pull cord on my whipper snipper however after fixing it im having trouble getting the actual motor back on to the shaft. It fits in but stops about 5mm short from all the way.
You probably have the counter weights from the shaft hitting the bottom of the piston skirt. To remedy this, you will have to pull the piston/connecting rod off of the shaft, turn it around and install it the other way. If you notice, the piston's skirt is longer on one side than the other in most cases.
Jan 09, 2011 | Garden
Pull cord won't pull
Check the shaft to see if there is something stuck in there. You can pull the wire shaft out to check. It is wire but looks like a small cable. Good luck...Lee
Aug 27, 2009 | Garden
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
