I have a cnm touchpad 7 and i had a password and the pad locked and i forgot password, how do i restart and delete password, because i cant get on it :L
  • 3,799 Answers
Look at this android forum.
http://www.androidtablets.net/
There are so many different tablets around it is difficult to be sure of exactly what you have.
Posted on May 01, 2013
2 Suggested Answers
awareprolt
  • 41 Answers
SOURCE: hp laptop windows 7. touchpad locks for no reason. how do i unlock it?
Search for the button for PAD LOCK, of press Fn + some other buton to unlock...
and next time write pc model.
Posted on Jul 09, 2012
My daughters my tablet2 by bush has,frozen what do I do
if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
When Hard Reset is Necessary for Smartphones or Tablets ?
1. Forgotten Pattern Lock on Android Tablets or Smartphones.
2.Too many pattern attempts / Reset user lock.
3. Tablets PC,Smartphones stuck on Gmail account.
4. Android Tablet PC stuck / freeze on Android logo.
5. Tablet Android or Smartphones hang on start-up / Multiple errors generating by OS.
6. Android market having problems or generating errors.
7.Upgrading to new Android version.
Make sure to charge battery upto 60%.
How to Hard Reset Argos CnM TouchPad Android tablet pc ?
  • Make sure the tablet is charged up to 60%
  • Turn off the tablet completely .
  • Press Volume + button , while holding Volume + button , plug in charger.
  • Release the volume + button.
  • Press Volume + again and press Power button to boot the CnM Tablet.
  • When Android logo appear , release the volume + button.
  • Press Power Button again and press volume + button , Recovery Menu will be appear .
  • Press the volume down and select "wipe data/factory reset"
  • Power button to select it
  • You will see "Yes - delete all user data"
  • Select "Yes"press "Power" button to select it
  • Formating will start. it will delete all user data .
  • Few seconds later, you should see the recovery menu again. Select reboot.
  • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
you are done.
This Hard Reset method will work with all models of CnM touchpad tablets.
Jul 25, 2014 | Audio Players & Recorders
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
CNM Touchpad 9 frozen
Did you fully charge the product?
Dec 30, 2013 | Audio Players & Recorders
I have a cnm touchpad 7 tablet with kindle installed. I cannot read any ebooks only ser the covers. What have I done wrong? Please.
I have the same touch pad, the fault is that the font color is the same as the background color, doesn't make any difference if you change the color. They are aware of this problem and promised there would be updates to fix it. So far I've installed 2 updates and it's still not working.......
Jan 01, 2013 | Computers & Internet
We forgot administrator password. we cant log on to computer . what can we do
This happened to me before but can no longer
change the admin password, so I have no
choice but to create a different user and
delete the old one. Here's how I did it:
1. Restart you computer
2. Press f5 before the windows logo appear
3. Select safe mode
4. Click start menu
5. Click control panel
6. Go to User accounts
7. You can. Ow delete that account and
create a new one
Hope this helps
Oct 17, 2011 | Computers & Internet
While deleting some files , not realizling it I deleted my touchpad ( what ) softwear . OR whatever its called , Now my touchpad isnt working. I have a compaq , about 4-5 yeasrs old , with windows7 up...
the touch pad should work even if you erased the files as it uses generic Human Interface Device drivers. Be careful that you didn't accidental disable the touchpad with the Fn+F2 or other Fn key combination(the key that you should combine with Fn has to has a touchpad icon on it) Another posibility is that you have enabled an option to disable the touchpad upon usb mouse connection. Also it would help if you gave me more details about what and where you erased.
Oct 16, 2011 | Compaq (153515-001) Touch Pad
Hi i have acer 5542g laptop currenty i got one problem i cant open any file or folder by double click on touchpad
Hi
Have you done all the windows updates ???
start
programs
windows updates
check for updates
install them all then restart laptop
if this does not correct things
start
right click my computer
go to computer properties
device manager
scroll down to find mouse/touchpad
un install it
restart laptop
windows should then on start up find new hardware
and install the touch-pad correctly
and may ask for another restart
if still no good try here www.acer.com
go to support/downloads
find you make model and operating system as in xp or vista or windows 7
then scroll down and find the touch-pad driver
download it
install it
restart and keep fingers crossed
good luck
Feb 19, 2011 | Computers & Internet
To clear sd memory card password
i cant to delete files from my memory card
Mar 20, 2010 | SanDisk 2GB microSD Memory Card
Can't reload os on cnm mini netbook
i have bought a cnm netbook and when trying to log onto internet it is asking for username nd password but i haven't created one so don't know what to put
Jan 06, 2010 | Televison & Video
Alps pointing device software
down load synaptics touchpad driver first.
once downloaded open the file to install.
before u install go into device manager..check mice and pointing devices and look for ps/2 compatable mouse....delete it and restart pc on restart it will find and reinstall ps/2 mouse.
if everything works,sorted ,if not install touchpad driver downloaded earlier.
you can find this driver on hp site.this driver works on all hp laptops.
Apr 07, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
