Question about Hoisting
Construction Hoist electrical diagram
Please send me a diagram of a Alimak Hek hoist model 500kg. year 1995 goods hoist
SOURCE: wire up a 3 phase motor to single phase 240v power
3ph motors will only run on 3ph power, trying to single phase will only burn up windings,
Posted on Dec 12, 2007
  • 5 Answers
SOURCE: hoist to lower spare tire does not work.
Same thing happened to me on my 2002 trailblazer. The last few wraps of the cable was corroded to the point that it wouldn't unwind with the tool supplied. First thing to do is cut the crimped end of the cable off with a grinder or cut off wheel but don't forget to support the spare. This will get the spare out of your way then simply take out the 3 mounting bolts for the cable hoist. At this point you could buy a new cable hoist from the dealer and install it yourself or you might be able to do what I did. I managed to pull and remove about a foot of the rusted cable, slide the rectangular metal piece, that actually holds the spare at the center of the wheel, back on the cable and attach a 1/4" cable clamp to the end of the cable which of course must be in good condition. There should still be enough cable to re-attach your spare to it and hoist it back up. Don't forget to lube things up so it won't happen again. Good luck. (buying a new one sounds better, doesn't it?)
mikethemedic in Hawley,Pa.
Posted on Jan 30, 2009
smartr10U
  • 1305 Answers
SOURCE: Replacing Chevy Trailblazer Spare tire mount/hoist.
Check out item 330335042615 on Ebay...
it''s the whole jack, handle etc... 50 bucks!
Tah dah!
Posted on Jun 09, 2009
SOURCE: ''2005 silverado stuck spare tire hoist''
How about a lot of rust under there?
Posted on Sep 30, 2009
SOURCE: spare tire won't release.
This is the worst GM engineering i have ever seen !!!! The secondary locking mech. rust itself in the locked position on will NOT allow the tire to lower. After lowering the tire down approx. 2-4" the saftey lock is still engaged. I was able to reach above the tire and remove the bolt holding the hoist in place. {15 mm wrench}. Keep a floor jack under the tire to support it and as not to fall on your head. After removing the bolt the hoist is hooked on the frame member and must be lifted off to remove. Once you get it on the garage floor it is possible to disengage the locking mech. with a few tools and a big hammer. Good luck This should be a Recall
Posted on Nov 29, 2009
Looking for a parts list for a Dayton 3Z372b electric hoist.
Dayton Hoist Parts - Ace Industries, Inc.
https://www.aceindustries.com/m-53-dayton-hoist-parts.aspx
Dayton Hoist Parts Online. Certified OEM DaytonParts in Stock Helpful Diagrams to Find Parts Fast. ...Dayton Electric Chain Hoist Parts. Basic Hoist(Figure 12) ...
[PDF]Dayton® Electric Chain Hoists - Ace Industries, Inc.
www.aceindustries.com/pdfs/Dayton/DaytonElectricChain-JLCManual.pdf
Dayton electric chain hoists are rugged, portablehoists that provide quick, precise ... Other features that ensure the safe operation of Dayton electricchain hoists.
Dayton Hoists Online - Ace Industries, Inc.
www.aceindustries.com/m-52-dayton.aspx
Coffing hoists and the Grainger Dayton electric hoists are the same identical units. The only
Apr 19, 2016 | Dayton Heating & Cooling
Can i get a wiring diagram for a westinghouse type FJ motor. it has a B145 frame; 1 phase; 110 v; westinghouse part #NO-1008
because it is 110 volts any work by yourself will be dangerous. take it to an accredited electrical motor rewinder for what you want and be safe.
Mar 06, 2015 | Miscellaneous
How to take an motor out of an 1976 Minnie
You need to take off the bumper and the door that covers engine access. You'll need a low boy engine hoist. Take out the radiator and push aside the AC condenser and oil cooler. Take off the fan blades from the watre pump pulley. Find a good place to hook up the chain on the hoist. Now go under the engine and remove the access cover on the bell housing. Take out the bolts that hold the torque converter to the flywheel. Now go after the bolts that hold the transmission to the engine. Put a floor jack under the transmission so it wont drop when you jack up the engine with the hoist. After you remove all the electrical wiring from the components on the engine remove the bolts on the motor mounts and raise the engine with the hoist . Pull the engine out while looking for anything that you didn't disconnect. Be sure the transmission doesn't drop when the engine separates from it.
Sep 30, 2014 | Cars & Trucks
What is OSHA and why do they need to inspect my wire hoist every year?
OSHA is the United states department of labor Occupational safety and health administration. They have to inspect your wire hoist every year to make sure that you and your employees are safe when they are using the wire hoists in your facility.
Nov 21, 2013 | Hoisting
Where can I find instruction for installing a wire hoist?
I found this set of instructions to be very detailed and helpful when I had to set up my wire hoist. Good luck and stay safe!
http://voices.yahoo.com/how-install-wire-rope-hoist-7673214.html?cat=6
Construction hoist Alimak hek 50a
You are in the wrong product category.
May 01, 2013 | Cars & Trucks
Tirak T3000 Hoist
Wow thanks for this. I was wondering if any one would know where I can get a <a href="http://www.legerpalans.com/anglais/pages/vente/palans.html">hoist</a>? If you know where I can get one please let me know. Thanks for any help.
Mar 26, 2013 | Computers & Internet
I can't find information on my chain hoist anywhere. what are some other names for the chain hoist?
the manual chain hoist can also be called the chain block, block and tackle, hand chain hoist, or manual chain block
Jan 16, 2013 | Hoisting
I need to replace the oil pan on a 1995 buick park avenue. Will I have to pull the motor out or can I just jack it up?
The easy way to do this is on a car hoist. The engine subframe can be removed quite easily allowing access to the oil pan as long as the engine is supported. If a hoist is not available, the next best way is to lilft the motor out of the car. Hope this helps.
Jun 19, 2010 | 1995 Buick Park Avenue
Hoisting Logo
717 people viewed this question
Top Hoisting Experts
JAIJITH
John Kopischke
John Kopischke
Level 1 Expert
gbob59
Are you a Hoisting Expert? Answer questions, earn points and help others
