Question about Desmond 49 cu. ft. / 1388 liter Freezer Gold Line GB14-GUL
Where can I find a compressor for this unit - Desmond 49 cu. ft. / 1388 liter Freezer Gold Line GB14-GUL
When defrosting, what causes loud banging noises?
Hello David;
My name is Peter. I am a retired field service refrigeration technician.
The noise is coming from one of two places.
1.) Freezer Fan - The fan may be hitting ice. After defrosting the noise will disappear.
2.) Compressor Flapper Valves - Remove the cover to expose the compressor. Plug the unit back in. If the compressor starts jumping unplug the unit. Check the rubber bushings where the compressor is bolted down. Are the bolts loose? Is the rubber torn off? If the compressor is secure, then you have a bad compressor.
Dec 30, 2014 | Freezers
Compressor never comes on
I made video how to replace compressor on true air beer cooler, should be the same for most of prep tables and etc. Hope That helps someone. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Apr 01, 2014 | True Freezers
Will not get cold
Hi Ebony! Are you having issues with the unit turning on at all and staying on? Or do you not hear the unit turning on and running? If you hear no noise, to show the unit is running (compressor turning on), you would need to contact a professional at your earliest convenience. The compressor and sealed system are not turning on. If you hear the compressor running, but the unit is not cooling you have a coolant/sealed system concern. Please contact Frigidaire and a professional to repair the unit.
Sep 04, 2013 | Frigidaire Freezer GLRT183TD
Frigidaire freezer compressor is hot to the touch and not cold inside
If the compressor is hot, then the temperature inside the unit may be compromised if there is a sealed system issue or a restriction in the unit. Call a professional to be safe.
Jul 26, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
Model Number - LFFU2065DWO. Been working fine until yesterday when we noticed some food thawing. I adjusted the thermostat but it keeps warming up. The fan is operating and the unit still pulls a vaccuum...
yuour compressor is busted the couse the compressor overlooad did trip... couse to shut down your compressor thats why its allways on heater mode..... call an refrigeration tech and replace your compressor and check your power meybe your have encountered an low voltage power breakdown to buned your compressor.
Aug 02, 2010 | Frigidaire Freezers
Compressor or fan not working
If compressor and all fans not working and unit has power.Check defrost timer maybe bad or sticks turn defrost timer knob if unit starts timer is bad.Timer only turns in one direction.
May 16, 2010 | Freezers
Older Amana upright freezer, I think that is 18 cu ft in size. It started making a clicking noise....I assume when the compressor is trying to start, it sounds like it is trying to start, but cannot
Hi, the clicking you are hearing is the compressor overload/external overload. When your compressor is a burn out or you have a locked rotor which means the compressor has died on you, it gets very hot from trying to start and this relay which is tied into the common side of the common terminal on the compressor, will click on and off as the unit tries to start. I have repaired these units for years and know exactly what is going on and the unit is older as you say. I would suggest pricing a new box as changing out the compressor, you are looking at around $1800.00 and up. I hate to tell you this but this is the problem. If you want to confirm this, just pull the unit out from the wall and try to leave it plugged in. Remove the lower panel to excess the compressor, condenser fan motor, and coil. Just be careful as this compressor should be very, very hot when you put your hand on it. Then you will know that is the problem. It should be warm and running. Please keep me posted and I hope I have been of help to you. Didn't want to give you the bad news though.
Good Luck, and Sincerely,
Shastalaker7
Mar 20, 2010 | Freezers
Compressor will not start
Take and close down the suction valve on the compressor and then try to start the unit after you recover some of the refrigerant out of the compressor the reason that it is acting like that is probebly because the compressor is full of refrigerant and slugging the valves. also verify the you have all the lesgs of power going to the unit. let me know how this turned out.
Dec 24, 2008 | Master Bilt 95 cu. ft. Commercial Freezer...
Freezers Logo
27 people viewed this question
Top Desmond Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Desmond Freezer Expert? Answer questions, earn points and help others
